    Results 1 to 20 of 27
      Dec 2009
      South Florida
      Can you ever have enough Horsepower?
      Also, I forgot to mention that the tank holds 2 Gallons. The plastic reservoir that comes with the kit is 3 quarts.
      1967 Chevelle SS Convertible
      1969 Camaro Ex-Race Car
      1967 Camaro RS/SS Top Sportsman (Sold-Now in Australia)
      Dec 2009
      South Florida
      Just had the car on the Dyno. After making some A/F adjustments, the car picked up about 70HP, making 1085HP.
      Jan 2010
      Elk River, MN
      Wow, that's got to be a handful. Thanks for the write-up, looks like a good product.
      Dec 2009
      South Florida
      A few Updates:
      Replaced the mufflers with DynoMax Welded (straight through) and removed the chambered mufflers. Increased the jet size on the dual nozzle meth squirters from 375's to 441's and opened up the back of the fresh air box for better direct air flow.
      The car will be hitting the Dyno on Tuesday and I will post updated HP numbers.
      Apr 2008
      La Verne CA
      Thats a trick setup to feed cool air to your procharger. A little off topic but is the electric fan mounted to the hood for additional coolingto pull the hot air out of the engine? Curious to know how well it has worked for you.
      Dec 2009
      South Florida
      Quote Originally Posted by twinturbo69 View Post
      The fan itself pulled about 5 degree's out of the temp that the car ran at. It took me from about 195 to 190. It also greatly reduced under hood temps. When I cut the two custom openings in the hood for the cold air box and to let additional heat out, it dropped the normal running temp to about 180 degrees.
      Jan 2010
      Delaware
      Beautiful setup, gorgeous car. I am also adding a meth injection system to the 1973 turbo 455 trans am I just bought. The car did 887 hp to the rear wheels on the dyno at 15 psi, so accounting for a 20% drivetrain loss with the automatic thats 1064 hp at the flywheel. Give or take its still a lot.
      The system I just bought was from coolingmist. Its a trunk mount system, 250 psi pump. I too wanted a larger tank, but didnt like anything under the hood.....I have limited space there in the first place. So this unit comes with a 1.5 gallon tank and the pump is mounted on the tank.
      David there talked me out of a complex controller. He said unless I was looking for the cool factor, just bring the entire system online at about 65% boost and be done with it. Considering the guy sells controlled systems, and he is the owner, and spent 15 minutes convincing me NOT to spend more money.....I conceded. LOL. I can always add it later.
      Very curious what your #'s will be with the larger cc nozzles you are installing. David recommended a 760cc, and a 380cc totalling 1140cc/min for my combo. Sounded like a lot to me, but I too was thinking about maybe just starting with the 760 nozzle, then adding the other to see the difference. Interesting that its so much more than you started with.
      Sounds to me like your setup is similar to mine in some ways, and I was expecting a 50-60 hp increase, as well as the added protection in addition to the intercooler to prevent detonation. From your example I think I'm at least inline with those estimates.
      Question........what percentage meth were you running on the dyno, and what do you plan to run regularly? Were the #'s on your dyno runs actual rear wheel hp, or corrected for drivetrain?
