    Page 9 of 19 FirstFirst ... 4 5 6 7 8 9 10 11 12 13 14 ... LastLast
    Results 161 to 180 of 376
    1. #161
      The calipers looks great. What was the deal with the Richmond 5 speed? Why the rebuild?
    2. #162
      Waterloo, Ia
      It was leaking oil and was scratching horribly on a hard shift into 2nd. Its a 15 year old tranny that's been beat to hell and back so i'm not even mad about synchros and seals. The work was actually fun and its like a new transmission now. Well worth my time.
      -Nick
      -1967 GTO I drive and race
      -Build threads:
    3. #163
      Quote Originally Posted by Nicks67GTO View Post
      My Richmond 6 speed crunches also ifI shift fast into second. Ugh...I am seriously considering sending it off to Liberty's Gear and having them convert it into a dog-ring box.
    4. #164
      Waterloo, Ia
      It might be time to toss some synchros in your 6 speed? It really wasn't too hard. Two quick pointers if you decide to do the synchros and seals. Make sure you have access to a hydraulic press for the front bearing and make sure you google shop around the Richmond part #'s. I found seals that Summit wanted 20 bucks for, on autoplicity, for like 7 cents. Yeah 7 cents... and they were even SKF seals. WTF?? I think I saved well over $150 bucks shopping it out.
      Dosen't the dog ring conversion require double clutching on downshifts?
      -Nick
      -Build threads:
    5. #165
      Waterloo, Ia
      As i'm currently waiting on wheels to show up I thought I would throw a quick few pics of my painted brakes. Nothing overly exciting but progress is progress. Friday i'm going to bake them in a buddies oven to cure. Iv'e got the coolest wife ever but i'm pretty sure she would f'ing kill me if I did that in our oven. Anyhow they turned out pretty good other than the hubs. The hubs look like dog ****...LOL. That's ok I guess as long as they don't rust!? I might end up pulling the front brake brackets back off, then blasting and painting them too if it looks like crap back there behind the wheels. The other day I didn't have access to a blast cabinet so for now they will stay zinc coated.
      I have a Moser 9" with #7900 housing ends. That's a 9" Torino bearing inside a 12bolt backing plate pattern. I decided that instead of pressing my old axle bearings off and buying new ones just to get the backing plates on, I would just cut the 02' Camaro backing plate in half. Before I did this I talked to Tobin @ Kore3. He thought it would be just fine but advised that if I cut it in between the caliper bracket bolt bosses that I should somehow brace it. So that's what I did. I braced first. Then made my cut. It turned out nice and shouldn't be an issue......here's a few shots...
      -Nick
      -Build threads:
    6. #166
      Jun 2012
      coolness, i may in the future get the same 9" rear setup so i can still use ls rear brakes... but then if you think about it explorer brakes are like $50 and PBR makes the mustang brakes so it stands to reason they're like the same brakes, from digging aroung my mustang projects i can sure say that the parking brake on an explorer is identical to the ls ones in my 12 bolts....
      your brakes look awsome man. trying to piece a getup for the front of my tempest now...
    7. #167
      Jul 2012
      Iowa
      Your brakes turned out pretty impressive.
      Miles Boyer
      The car hobby is dangerous,if the speed doesn't kill you, the cost of parts will.
      91 V8 S10
      88 Cutlass Pro-Tour
      97 Chevy lifted Z-71
      96 Corvette
    8. #168
      Apr 2007
      Austin, TX
      Country Flag: Mexico
      pretty cool idea on the caliper bracket
      really the 4 bolts on the flange should provide enough clamping force to prevent it from separating, add in the actual caliper and its more than enough, but I think the little bracket that goes between the caliper ears is good as well.
      maybe you could have had some one fab a cross brace that used the caliper ears?
    9. #169
      Waterloo, Ia
      Quote Originally Posted by captainofiron View Post
      When I talked to Tobin about it he just suggested that I reconnect the two halves somehow just to be sure the caliper wouldn't distort anything under pressure. I'm thinking this should do?
      -Nick
      -Build threads:
    10. #170
      Thanks for the tips. Dog-rings just need to be rev-matched for quick downshifting or you can double clutch just driving around town.
    11. #171
      Oct 2014
      So Cal
      Hey I'm curious about this Jeep steering box swap, haven't seen that before. What other parts did you need to get it to work right? Thanks!
    12. #172
      Apr 2007
      Austin, TX
      Yea I think its more than enough
      if you think about it, in order for the halves to separate you would need to shear/yield an axle hub bolt, AND deform the actual caliper/cage
      and thats alot of required load
      the caliper cage essentially does the same thing the added bracket does
    13. #173
      Waterloo, Ia
      Quote Originally Posted by HomeBuilt View Post
      Hey there. Well It requires the Jeep box, the 1970-later power steering regulator, stock power steering lines and power steering pitman arm work, 2-5 dollar aluminum fittings from Lee Mfg. and an autozone ragjoint. I did a thread on it on another board. Its a bolt in deal. Let me dig for a link. It was a few years ago now and I don't remember all the info but its a really common swap. A quick google search should bring up threads on boards about it.....
      -Nick
      -Build threads:
    14. #174
      Waterloo, Ia
      And here is my Jeep box swap post from the performance years board..... Its an awesome upgrade for the $. Any other questions let me know!
      http://forums.performanceyears.com/f...=685111&page=4
      -Nick
      -Build threads:
    15. #175
      Oct 2014
      So Cal
      Thanks, Nick I appreciate it!
      David S.
      1969 Chevrolet Chevelle
      406 SBC, 507hp
      700R4 by Monster Transmissions
      Hotchkis TVS Extreme
      "Slowly building something fast..."
      https://www.pro-touring.com/threads/...-1969-Chevelle
    16. #176
      http://www.chevelles.com/forums/showthread.php?t=334534
    17. #177
      Waterloo, Ia
      Look what the UPS guy left for me this afternoon! I might take Thursday and Friday off, do my brake project and get these mounted!
      -Nick
      -Build threads:
    18. #178
      FRANCE
      Country Flag: France
    19. #179
      Apr 2007
      Austin, TX
      Nice!
    20. #180
      Waterloo, Ia
      Well its time to post up some shots of the new brakes, wheels and tires. I'm still working on the master cylinder, booster and lines. I should get those done this weekend and ill update.
      -Billet Specialty Mag G's
      -Fronts are 18x8 with a 5" BS and a 245/45/18 Nitto555
      -Rears are 18x9 with a 5.75" BS and 265/50/18 Nittto555
      -Front brakes are Kore3 Z51 with Stoptech slotted rotors
      -Rear brakes are 2002 Camaro with Stoptech slotted rotors
      -Both ends have Hawk HPS pads
      I ended up with a 1/4" spacer in the rear. I was torn between 5.5" BS and 5.75"....Well 5.75 worked but 5.5 would have been perfect. I wanted to error on the side of being able to push them out as opposed to having to trim the wells so that's where my decision was made. Fronts are spot on
      This spring I might mess with ride height. I'm going to drive it as is for a bit and then lower the front 1" Its sitting a bit high I think....well here she is
      -Nick
      -Build threads:
