    Results 1 to 18 of 18
    Thread: Fuel Question
      Melbourne, FL
      Quote Originally Posted by Vegas69 View Post
      It depends on the application. In a high horse application that will see many full throttle runs, I want to see a return. Your pump is running at full bore all the time and there is no delay in fuel volume when you decide to mash the gas.
      Reviving an old thread since I'm about to start plumbing my fuel system.
      So, for say a 470 c.i. car making in the 500-550 hp range that ia mainly street driven in Florida a rerturn line is not reaaly needed?? I don't think I ran one on my previous motor either. I guess if I have any heat related vapor lock issues I could always add a return line later since I have already purchased a return style regulator. I can plug the return now and see how things go. Or should I just go a head and plumb a return line now??
      Are there any negative effects to using a return line on a carberated motor?? I'll be running a ProComp PC-2803 "Black" fuel pump with a Mallory 4309 regulator.
