    Results 1 to 20 of 24
      Miami, Florida
      Help me out MODS...
      Hey guys...Help me out with resizing my GIF from the old board. My bikini bouncing Pontiac fan club leader is getting lonely over there!!
      Kevin
      Kevin.
      69 Firebird "Eternity"
      Jul 2002
      Mesquite, TX
      No image editing tools available here at work. If nobody else is able to during the day, I'll give it a shot when I get home.
      Miami, Florida
      Thanks Derek
      I miss my sweetie pie so.
      Kevin.
      Nov 2001
      Sacramento Ca
      you want her for your Avatar? 80x80 ?
      Tony Langlois
      1966 Corvair Monza
      Nov 2001
      Sacramento Ca
      and heeeeeere she is!!!
      Tony Langlois
      1966 Corvair Monza
      Miami, Florida
      SWEEEeeeetttt.
      Kevin.
      Miami, Florida
      Tony...
      Avatar option gives me this message when I insert the URL..
      "The file that you have tried to attach is too big. The maximum size is 30000 bytes."
      Under properties "Bikini" is 31490 bytes I think.
      Is this something that can be changed as well???
      Kevin.
      Jul 2002
      Mesquite, TX
      It's still too big, I believe.. looks like 58x105 and I think the Avatar is limited to either 80x80 or 100x100, either way shrinking it a little further should get you fixed up - I would think even if it's shrunk to 100 high that would get you the 1500 bytes you're over.
      Actually, by highlighting the pic it looks like most of the top quarter of the pic is blank space and could probably be removed. That would definitely get you small enough.
      Nov 2001
      Sacramento Ca
      this is as small as i can get it.
      its still too big, 3100 kb. she's only 80 pixels tall for me.
      Tony Langlois
      1966 Corvair Monza
      Miami, Florida
      It's strange that the biggest image that Tony posted is actually larger in size but lower in bytes???
      Kevin.
      Jul 2002
      Mesquite, TX
      That is indeed odd.
      Tony, what software are you using to resize animated .gifs? I'm wondering if maybe a different software package would have some better compression?
      Jul 2002
      Muskegon, MI
      That last one shoudl work since its only 58x80 pixels. Yeah Tony what are you using for those animated gifs? I can do it at home but not at work.
      Nov 2001
      Sacramento Ca
      easy gif animator version 2.12
      the problem is, as it shrinks the first image, the colors changed alot. as did the dpi. I'll try to compress and optimize it.
      oh. and on my avatar screen it says anything over 2000 is too big.
      Tony Langlois
      1966 Corvair Monza
      Nov 2001
      Sacramento Ca
      got it down to 22.9 kb !
      Tony Langlois
      1966 Corvair Monza
      Caledonia, MI
      Here
      This one should work for you.
      Jason Mitchell
      1969 Camaro @ Dutchboys
      Caledonia, MI
      Wow all kinds of new posts while I was editing that gif. Mine was done with Photoshop ImageReady. I think it was 18.6 KG
      Jason Mitchell
      Nov 2001
      Sacramento Ca
      cool jason.
      heres the one that will work, hosted on the net for ya.
      Tony Langlois
      1966 Corvair Monza
      Miami, Florida
      She still won't go into the custome avatar URL slot. It doesn't give me any error messages, the page just resets without changing??
      Kevin.
      Jul 2002
      Muskegon, MI
      Try right clicking on the avatar he made for you, then go to "properties" and copy the address(url) and paste it. That should work for sure.
      Nov 2001
      Sacramento Ca
      it'll take a few tries kev. Mine did. if all else fails, save the pic to your harddrive and use the browse feature, then click save changes. It'll take forever for it to upload. But it does work.
      Tony Langlois
      1966 Corvair Monza
