      New Orleans, La
      Fuel system Question.
      I am doing some shopping for fuel system fittings. I am having trouble finding a fitting to go from 10AN to the stock LS1 fuel rail. I have found the quick connect fittings for LT motors on jegs, are they the same ones needed on the LS motors?
      Dallas
      Oct 2007
      Paducah, KY
      I have a fuel cell and what I've done is go from a -10 to -6 reducer barb fitting (push loc hose type), low pressure hose, Walbro 255 pump, high pressure hose to C5 filter/regulator, 3/8 hard/plastic fuel line to quick connect on fuel rail. I'm using 3/8's line on everything which is -6. Got basically everything from Rock Auto and Midway something I think. Quick connects, low pressure hose, good clamps, C5 regulator/filter. Return I have a -8 to -6 reducer w/barb fitting(also push loc hose type). Hope this might help ya.
      Darren
      New Orleans, La
      Did you use an fittings for the quick connect or was that tubing fittings. Also how far did you mount your fpr from the tank?
      Oct 2007
      Paducah, KY
      http://www.midwayautosupply.com/p-44...-800-0825.aspx
      Tubing. Above are the quick connect fittings I'm using and where I got them from. I would say the C5 filter/reg is probably about 4 ft from my cell. I have my pump by my passenger leaf spring mount, then the f/reg on the frame rail right after my axle (if ur behind the car looking to the front).
      Darren
