    Page 3 of 6 FirstFirst 1 2 3 4 5 6 LastLast
    Results 41 to 60 of 102
    Thread: 92 s10
    1. #41
      Cornettsville, ky
      bravada grill looks neat
      nice truck
    2. #42
      Oct 2007
      Newark DE
      One of my favorite trucks.
      Looking forward to updates.
    3. #43
      Jan 2009
      Houston, TX
      Sweet... another place to check on
      I think I need to follow your lead and transfer an entire build thread here.... though mine is NO WHERE NEAR as clean as yours.
    4. #44
      Aug 2008
      new braunfels, tx
      thanks for the compliments everyone. duane you should transfer your build thread over here.
      for xmas the wife got me a tfs-3150800 trick flow air inlet elbow, a Mr. Gasket Master Cylinder Cover MRG-4573, and made for you wire looms MFY-5035611.
      my mom got me a $80 gift card to eckler's corvette, which i promptly used to buy a a7721 corvette lower shifter boot and a
      51799 corvette upper shifter boot. these will work well w/ my syty center console.
      awhile ago i bought a ctf-df039020 centerforce dual friction clutch. also picked up a motormite pilot tool 14523 and a motorite pilot bearing 14650.
      the above transmission stuff installed:
      the top bellhousing fin ground off for more clearance:
      fighting w/ the headers. they have to go in while installing the LT1; clearances are that tight.
      getting there:
    5. #45
      Aug 2008
      new braunfels, tx
      intake set on just for grins:
      transmission and collector pic:
      next up will be figuring out what to do about my transmission crossmember. i'm going to try to use my stock 700R4 crossmember, but if worse comes to worse i'll just make one.
      also cleaned up, masked, and painted my 58mm TB.
    6. #46
      Trucks looking good, haven't seen it in a while.
      330 H.O. gm crate, edelbrock carb/intake, headman headers,T-56 6 speed, mcleod clutch, hurst shifter looking for a home.
      1969 Camaro- under eternal restoration
    7. #47
      Oct 2006
      Pittsburgh, PA
      Whoa.
      I'm jealous of this truck... :
    8. #48
      Lafayette
      great progress joe....i wish i had that much done..
      Scott
      Built LTX, TKO600, 12Bolt
    9. #49
      iceland
      Country Flag: Iceland
    10. #50
      Jan 2009
      wow. your truck is outrageously clean! i am another 1st gen S-10 member, my truck looks like a piece compared to this. i will post some build pics too when it gets a little further along.
      love the truck
    11. #51
      Oct 2008
      Toronto
      awesome buildup!
      95 SVT Cobra. 306 HCI, IRS and much more!
    12. #52
      Sep 2007
      Columbia, SC
      This thread makes me want to mod the hell out of my 92 Sonoma daily driver!
      Kevin McEvoy
      1968 Firebird
      she's a little rough
    13. #53
      Janesville, WI
      Great project!
      I have a soft spot for 1st gen s-10s. One of these days I think I will swing down south for a rust free example and build it up.
      Did I read correctly that you waxed your frame-rails? That is hard core brother!
      -Shaun-
      L92/T56 Stalker 1711 pounds, LS power!
      73 Buick Century L92/T56 swap in progress
    14. #54
      the o.c.
      i really really like this truck. any updates?
    15. #55
      Aug 2008
      new braunfels, tx
      thanks for the compliments guys, i do appreciate it all!
      bought some stuff. sparco pedals, GMC grille, black powder coated grille insert.
      gas tank installed. the 13g is so cute compared to the stock 20g :D.
      i ended up using bicycle inner tubes as pads/dampeners for the gas tank. they were free (you can pick up old ones at any bike shop) and won't rot like whatever it is GM used as pads.
      i've been fartin' around w/ the interior as well. going to go w/ an all black interior. the truck is a 1992, and the interior is (was) blue. pure 80s, so it's time to update.
      also figured out how i'm going to mount the SRT-4 neon seats in my truck. i'm basically going to cut off the "feet" of my stock seat tracks, then bolt those my floorboard, mate them to the SRT-4 seat tracks w/ a couple of spot welds, then remove and finish weld. i can't weld, but my friend is getting pretty good at it so i'm going to give him a shot.
      SRT-4 tracks on the left and stock s10 on the right. the blue tape denotes where i made my cuts. more to come.
    16. #56
      Oct 2007
      Newark DE
      No more Bravada grille?
    17. #57
      Sep 2007
      Buford, GA
      The quick and dirty project thread. I like it. Might have to copy mine over here some day. Looking forward to more updates when they arrive!
      Adam
      1985 S10 - LT1 + T56
    18. #58
      you should sell that bravada grille and cheap to me! love it.... brings me back to building my truck
    19. #59
      Eastern Virginia
      Hey do you still have the 315 tires on the 9.5" wide centerline wheels? How dodid they fit?
      Scot
      86 Monte SS
    20. #60
      Dayton Ohio
