    Results 1 to 20 of 182
      While a recess is not needed to fit the engine in the car, I would be worried about future maintenance work. In my GTO the engine is in the factory location. I've had to remove the transmission to do some service work and I can tell you that when the engine tips down in the rear, it gets very close to the firewall. If the engine was to be moved back 2" without adding room at the firewall, there will be problems when the time comes to pull the transmission.
      Nice work Fesler crew!
