    Results 1 to 18 of 18
      Jul 2008
      ohio
      break heeeeeeeeeeellp
      what would be a pretty easy conversion and on the wallet as well for a 73 nova with 10 bolt rearend maybe get a disc braking system of a newer car from the junkyard that will bolt on the nova sorry don't know a lot about brake conversions
      Jul 2008
      ohio
      what don't anyone know i have had 18 views and not even eny suggestions?
      Walla Walla, WA
      Quote Originally Posted by craigs73
      I think if you did a search both on this site and on the internet generally you'd get a lot of information on this swap. Then, if you had specific questions about using a particular setup, I think you'd get the information you need.
      Mike Kelcy - '68 Camaro with some stuff done to it.
      Aug 2006
      San Francisco, CA
      There's some information on my build thread in my signature
      (shameless plug)
      Steven
      1968 Camaro: Project "TRACKDAY"
      Latest Track Weekend Video
      Build in Progress
      Mountain Springs, Texas
      You can use LS1 brakes off a 4th gen F body. Here is one kit to do the conversion:
      http://ssl.hostingplatform.com/30729...Code=brakekits
      Don
      Oct 2005
      Graves County, Ky
      Give it time, some one that knows about disc brakes will answer your question. I'd like to know the answer also.
      Aug 2005
      Hamilton, NJ
      Maybe I have my nova years wrong, but I think any solution you find that works for a 1st gen camaro will work.
      Scott from NJ.
      Vent Windows Forever! ...
      Everett, WA
      Yep, 1st gen Camaro will work for a 3rd gen Nova (except for '67 Camaros... they don't use offset shocks). LS1 brakes is one solution, or you can get an aftermarket kit. Keep in mind that disc brakes will move your wheels out just a touch due to the thickness difference between the drum and the disc rotor.
      The few, the proud, the crazy... the LT1 owners.
      Oregon
      It would also help to know what front brakes you are running so that balance is taken into consideration, what size wheels you have since that could rule out a lot of the late-model options, and what your budget is...if you have one. "Easy on the wallet" for some is not what it is for others.
      What's wrong with your drums? They are going to be the cheapest rear brake solution hands down and typically have the best parking brakes to boot.
      Tobin
      KORE3
      It's what I does.
      Jul 2008
      ohio
      i am going to be running 17's all the way around and the front is a stock disc break i just wanted the disc on the back for little better stoping and looks better than the drums on rims that you can see the braking system. i like the 4th gen solution alot would be cheap to do.As for the budget i would say not a hole lot of room but it depends on what it cost to no rather i could afford it and or save a little out of a couple checks
      Oregon
      Either the LT1 or LS1 fourth gen F-body rear disc setups would probably work well for you and have the added benefit that if you ever chose to upgrade the front discs to something with a little more capacity like a C5/C6 setup, you wouldn't have to upgrade the rears again at the same time. BRP sells the spacers to make up for the difference in brake offset dimension between the early and late-model 10/12-bolts.
      Tobin
      KORE3
      It's what I does.
      Jul 2008
      ohio
      would i have to upgrade my brake booster or master cylinder since i would be makeing the back disc and if i do will the booster or master cylinder of the 4th gen cars work?
      Oregon
      You shouldn't have to change your MC/booster, just pull the residual pressure valve from the rear circuit (if it has one) and you should be good to go. When you upgrade your front calipers, you'll probably have to reduce your MC bore size...but there's no reason to do it until that point in time.
      Tobin
      KORE3
      It's what I does.
      Jul 2008
      ohio
      is 200 dollars a good deal on a used 98-02 carmero complete rearend. this is at my local junkyard and does it matter if it is traction control or not and what size rearend is it.10 bolt,8.5??
      Those rearends are worthless as far as I know. You should be able to buy all the brake parts somewhere for less than $200 if that is all you want.
      Don
      Houston, Tx
      Quote Originally Posted by dhutton
      Don
      Yep... i have seen disk to disk rears for under $300...
      You should be able to get the disk brake setup for < $150
      you really only need the mounting brackets and backing plates. I would get new loaded calipers from the auto parts store to save some work and know that you are getting a good setup
      Jul 2008
      ohio
      so i need to get two RH calipers and brackets off of a 4th gen
      Newbury Park, CA
      You will need two RH brackets and calipers if using the earlier 4th gen LT1 setup.
      More info here.
      http://www.geocities.com/torkerscamaro/torker.html
