Results 1 to 20 of 25
Thread: JKnight16's 69 GTO
07-13-2008 #1
JKnight16's 69 GTO
This is my dad's car but we're working together to get this thing looking and driving right for Hot August Nights this year. Anyhow, we got the 17's from Jon at DriverzInc. mounted up (225/50-17 in front, 275/45?-17 rear) and it really revealed how high the front of this car sits right now. So we need some assistance from you GTO or A-body guys.
The rear springs are OEM replacements for a tempest wagon, so they likely sit a bit higher than normal, higher spring rate, but we don't know what the front springs are, except that they're fairly old. We're thinking these fronts may be even taller than stock, but aren't sure. Either way, we're looking at replacing all four springs with some eibachs or hotchkis lowering springs, but we're a little concerned that even that won't get the front end low enough. What has your experience been with lowering springs on an a-body? how did yours compare to the pic below? The rest of the suspension is stock.
(Oh, and don't worry about the rear drums, the Wilwoods are on the way from Frank!)
Thanks for your input guys.
Edit: For comparison, this is after installing SPC springs and Stage 2+ system from Marcus at SC&C
Jeff K.
69 Camaro SS, 406 SBC, TKO600, 9" w/3.73 tru-trac, Speedtech Arms, AFX Spindles, Lee 670 Box, Baer GT front, C5Z rear. Hyperco Leafs w/ Fays2 Watts Link + Varishocks.
07-13-2008 #2
- Feb 2006
- 478
I would cut a coil out all the way around or you may just start with 1/2 a coil and and go from there. You can take a die grinder and a cutoff wheel and it will slice it right off. I doubt a hack saw will do much.
In the rear, you will need to make sure once you get it where you want it, that the shocks are short enough not to let the rear drop enough to let the coil fall out. If so you will need to make a limiter or get some shorter shocks. Min 67 is lowered 3" and Edelbrock IAS shocks were just short enough to make it.
I cut my front springs a full coil and that was just about right, but that put the car about 3" lower than factory. That is lowwwww. For the rear I used OPG 3" lowering spring because my springs are double pigtail. If your are just single pigtail, you can just trim them in the back.
07-14-2008 #3Just to clarify, so you're talking about buying the new springs and then cutting them a half a coil, maybe a full coil?
So you guys out there that have used aftermarket springs on your A-bodies, is this similar to what yours looked like w/ factory springs? How much did yours change with the aftermarket springs installed?Jeff K.
07-14-2008 #4
