Results 1 to 9 of 9
Thread: LS2 Swap 67 camaro Radiator help
04-03-2008 #1
Banned
- Jan 2008
- 288
Can I run my stock Radiator without fans? Or will I run into overheating issues. Had a 600 RWHP SBC in before and never had overheating issues ever
04-03-2008 #2
Banned
- Jan 2008
- 288
And also anyone have a part number or a link to a good aluminum radiator and electric fan? Maybe the afco? Couldn't find it on the site. I'll keep searching
04-04-2008 #3
I have a Ron Davis in mine and was told that I can have the AC going in bumper to bumper traffic on a 110 degree day.
04-09-2008 #4
Starting The Transformation
- Jan 2008
- Felton, DE
- 346
I used an LT1 radiator and electric fans. They can be had pretty cheaply. I got mine from a $100 parts Z28 i have. The factory LS1 hoses lined up perfect. Had to trim about a 1/2" off of the lower radiator hose to make it fit exactly. I just botled the top flange of the radiator to the radiator support and used a 90* piece of aluminum to do the same for the bottom.
You guys arent runing ANY kind of fan with your engine? I sure would like the piece of mind. I guess I'm used to the newer vette and fbody style setup with the air dams being the only means of air passing through.1994 Z28 - 13.52@110mph 2.1 60ft T56, bolt-ons, suspension
1978 Datsun 2+2 - 6.0L LS1 swap in progress
1968 Firebird, 2820 dry- 2000 LS1, D&D Viper T56, RAM clutch/flywheel, 236/236 .651/.651 110+4LSA cam, victor JR EFI, 4150 TB, 42lbers, painless harness, Moroso 7qt pan, sfc, trac bars, 3" x pipe side exits, Telstars-30"MT streets/skinnies, mini-tub, 8.5" posi, richmond 4.56s, Hooker lLTs, Denny N20 DS, Fast dual wideband, Shotgun street scoop.
http://www.myspace.com/shawnmacananny
04-10-2008 #5
Banned
- Jan 2008
- 288
shawn-thanks for the info
Anyone used a radiator out of an LS1 vette or camaro?
04-10-2008 #6
- Jan 2008
- Felton, DE
- 346
I have heard of a few guys using the ls1 radiators and fans. Havent hear of anyone using one from a vette although i'm sure it could be done. There is alot of room on the front of these cars.
here's a pic of my lt1 radiator and fans in.
http://www.ls1tech.com/forums/attach...9&d=1207789415
04-22-2008 #7
Banned
- Jan 2008
- 288
Shawn- Did that fit in the stock radiator support or did u take the support out of the z28?
04-22-2008 #8
- Jan 2008
- Felton, DE
- 346
It fit with the stock 68 camaro radiator support.
04-23-2008 #9
