    Results 1 to 9 of 9
      LS2 Swap 67 camaro Radiator help
      Can I run my stock Radiator without fans? Or will I run into overheating issues. Had a 600 RWHP SBC in before and never had overheating issues ever
      And also anyone have a part number or a link to a good aluminum radiator and electric fan? Maybe the afco? Couldn't find it on the site. I'll keep searching
      Apr 2008
      I have a Ron Davis in mine and was told that I can have the AC going in bumper to bumper traffic on a 110 degree day.
      Felton, DE
      I used an LT1 radiator and electric fans. They can be had pretty cheaply. I got mine from a $100 parts Z28 i have. The factory LS1 hoses lined up perfect. Had to trim about a 1/2" off of the lower radiator hose to make it fit exactly. I just botled the top flange of the radiator to the radiator support and used a 90* piece of aluminum to do the same for the bottom.
      You guys arent runing ANY kind of fan with your engine? I sure would like the piece of mind. I guess I'm used to the newer vette and fbody style setup with the air dams being the only means of air passing through.
      1994 Z28 - 13.52@110mph 2.1 60ft T56, bolt-ons, suspension
      1978 Datsun 2+2 - 6.0L LS1 swap in progress
      1968 Firebird, 2820 dry- 2000 LS1, D&D Viper T56, RAM clutch/flywheel, 236/236 .651/.651 110+4LSA cam, victor JR EFI, 4150 TB, 42lbers, painless harness, Moroso 7qt pan, sfc, trac bars, 3" x pipe side exits, Telstars-30"MT streets/skinnies, mini-tub, 8.5" posi, richmond 4.56s, Hooker lLTs, Denny N20 DS, Fast dual wideband, Shotgun street scoop.
      http://www.myspace.com/shawnmacananny
      shawn-thanks for the info
      Anyone used a radiator out of an LS1 vette or camaro?
      Felton, DE
      I have heard of a few guys using the ls1 radiators and fans. Havent hear of anyone using one from a vette although i'm sure it could be done. There is alot of room on the front of these cars.
      here's a pic of my lt1 radiator and fans in.
      http://www.ls1tech.com/forums/attach...9&d=1207789415
      Shawn- Did that fit in the stock radiator support or did u take the support out of the z28?
      Felton, DE
      It fit with the stock 68 camaro radiator support.
      Jul 2001
      Detroit, Michigan
      I'm going to run my original radiator with my LS1. I'll put electric fans on it and I don't foresee any problems. All radiators do the same thing, the concept is the same for any engine.
      1968 Pro-Touring Camaro LS1
      Project: Next Year
      - Start date; June '01
