Results 61 to 80 of 146
Thread: chassis jig design
Kevin - that is quite the setup!
After doing some welding, I did decide to add some cross braces, just to ensure it does stay true. Amazing what steel will do with heat! The tubing I am using is 3"x3"x .25", so it is fairly stiff. The cross bracing is mainly to ensure the structure keeps its shape after welding, and will provide more stiffness to the system (although not the intent). I will meet you halfway with bracing David
. The way I can still get the creeper under the car with no issues. It also worked out with some extra shorter 2"x2"x3/16" material I had on hand. The braces will be stitch welded on, and then the legs will be fully welded after that.
I did run FEA on the original piece, and even if I load up the jig between the posts will 4000lb (1000 each spot), the deflection is a fraction of a mm, and this also takes into account that it is not bolted to the floor and is free to pivot about the floor. I will have to re-run with the new braces.
I have it almost done - I will have to post more pictures. I am hoping to have this under my car within the week.
