    Results 1 to 11 of 11
      Sep 2007
      Missouri City, Texas
      Need Help On Primer
      Have sanded my car down to metal.
      Now I am asking for recommendations on what would be the best way to go from here. Primer, basecoat, clear, etc.
      My first paint project.
      Thanks.
      Sep 2007
      Elizabeth City NC
      if you got bare metal go with a epoxy type primer first.
      67 camaro
      Mountain Springs, Texas
      It's not a good idea to leave a car in bare metal for any length of time. It should be coated with epoxy primer very soon as stated above.
      Don
      Sep 2007
      Primer/paint
      Is there a specific primer you recommend?
      Brand and part number?
      Thanks.
      One reasonably cost effective option is the epoxy from Southern Polyurethanes that you can have shipped to you. I've also used their 2K high build primer. Barry is very helpful and they ship quickly, usually the same day.
      www.southernpolyurethanes.com
      DP40 (different colors are available, for example DP90) from PPG is another option that you can probably find locally.
      Make sure you wear a high quality respirator. Epoxy primer is some serious stuff that you don't want in your lungs.
      Lots of good information over on camaros.net in the bodyshop forum and also in the tech archives.
      Don
      Sep 2007
      Elizabeth City NC
      and the dupont version is also avail. in different colors the med gray is 2540s. If you got a local paint store Im sure they can tell you which brands they carry.
      67 camaro
      ppg dp90
      Metamora, Illinois
      ppg dp90 and then a coat of k36 high fill primer
      Sep 2007
      Primer
      OK, I was told that if I use PPG, Dupont, etc, then it is best to use the same brand for paint, reducer and clear.
      Sep 2007
      Elizabeth City NC
      Quote Originally Posted by jag4902
      You can use different primer than the finish coats but It is a good Idea to keep all the same brand products.
      67 camaro
      Sep 2007
      OK, Thanks.
