    Page 24 of 35 FirstFirst ... 14 19 20 21 22 23 24 25 26 27 28 29 34 ... LastLast
    Results 461 to 480 of 681
    Thread: Project FNQUIK
    1. #461
      Hey Wayne,
      Glad those terminals worked out for you. I would also add a wire to the S terminal and run that to your main power distribution point.
    2. #462
      Mar 2015
      FL
      I'm hoping!! Giving it my best.
      Looking forward to it. Keep up the good work.
      -Mitch
      G8 GXP, White Hot, Auto, bone stock
      68 Firebird, 428 Pontiac, CNC'd KRE Al d-ports, hyd roller, EFI, TKO600, TCI Eng complete chassis, Ridetech, Kore3 C6Z brakes, C5Z 18" with 315 rivals x4, C6zr1 mufflers
      RRR, NASA HPDE https://youtu.be/DPp1l9-FuNE
    3. #463
      May 2008
      Austin, Tx.
      Looking great Wayne! That shifter looks sweet in that console.
      The heat seems to be extra brutal this summer. Either that or the older I get, I probably just can't hack it like I used to...
      Keep grinding. It's great to see the updates.
      Ray
    4. #464
      Thanks again Andrew.
      Thanks Mitch.
      Ray same here with the heat. Unfortunately as much as I hate to admit it it's the older with me! You have a double whammy where you live.
    5. #465
      I had to change one bolt on the drivers side for the brake kit. No one had one anywhere around me not even my go to Aquidneck fasteners. I had to order them from McMaster-Carr, which they were great I ordered 2AM Monday and had them 4pm Tuesday. Can't ask for anything better than that. The drivers side is all put back together with the caliper all shimmed and ready to go with the e brake inside the hub.
      Now the passenger side is another story. I put all the shims on the axle because of the weird off set i had made ( totally my fault ) so we put the bolts in and start tightening them up, grade 8 fine thread with crush nuts. ( slightly out of round for a locking effect.) First three going fine just to snug for an even clamping. Go around again to finish tighten same three fine fourth one Seized like you wouldn't believe! I'm not a little guy and my buddy has hands twice my size, it kicked the crap out of us!! Wouldn't budge we tried everything we had. Only one thing left. Die grinder with a cut off wheel. First we had to dis connect the coil over for room then get ready for some fun. we sliced the head of the bolt and he got under there and chiseled the rest off. which went pretty easy for what we were expecting it to be. Luckily I ordered 2 extra bolts. But that ended the fun for the day.
      This is the one that's done
      Here's the carnage.
      and the cause of the problem. When I had the rear built it got old Ford big bearings and I wanted the in hat parking brake and it needed different off set on the axle. so a special kit had to be put together. The kit is great but getting the housing ends to work is all the fun.
    6. #466
      Sep 2009
      Looking good! Can't wait to see the start up video!
    7. #467
      Thanks I'm getting psyched to get it going too.
      I finished the other side of the rear brakes yesterday.
      I've got some family stuff going on for a few weeks so I'll be off the car for a while.
    8. #468
      I was looking at a couple of sets of Recaro seats, but missed out on both of them so I picked these up.
    9. #469
      I just got back from 2 weeks in Fla. (We missed Irma). Then a week in Va for my grandsons Baptism.
      I finished epoxying in the Auto Meter gauge pod on my 5th gen console, here's a couple of quick shots of it.
      I"ll finish it with a thin coat of filler and then probably have it hydro dipped.
      Seats came in Tuesday they look pretty good.
    10. #470
      I got the gauge pod filled and primed, now to decide whether to paint or have it Hydro dipped.
    11. #471
      Feb 2016
      SoCal
      Wayne - Thats looking real good. What color or pattern would you dip it if you went that route?
      1970 VW Bug - Just your average mid engine Bug
      Track toy - 06 Evo - E85 and lots of boost
      Newest track toy - 2021 Supra
    12. #472
      Aug 2015
      Heber City Utah
      Wow super clean very nice !!
    13. #473
      Quote Originally Posted by Bugzilla View Post
      Thanks! Not sure yet. I was thinking carbon fiber print, I also like the color it was or a little darker silver/gray. I'd like to do something I can tie into the Dash instrument panel.
    14. #474
      Sep 2013
      sw Kansas
      Looks good, Wayne.
    15. #475
      Jun 2014
      California
      This center console is inspiring! Great work!
    16. #476
      Apr 2007
      Utah
      The console is coming out looking great Wayne.
      Sam
      Northern UT.
      '68 Camaro "Bodacious"
      '56 210 2dr "Buckshot"
    17. #477
      Thanks guys, I appreciate you checking it out. I'm going to give it a couple of more coats then decide whether to paint od hydro dip .
    18. #478
      Nov 2010
      You could hydro dip Carbon Fiber....
    19. #479
      May 2008
      Austin, Tx.
      Hey Wayne,
      The fab work on the console looks great! That gauge pod setup from the ‘69 Z28 setup looks great. In my opinion, one of the most iconic setups from the muscle car era.
      Getting closer and closer!
      Ray
    20. #480
      Mike, Jeff (jwcarguy) has one in his car and that's where I saw it in Carbon Fiber and liked it. I was thinking of rosewood to match the pieces for the radio and the left side of the dash, not sure it would be too much. Maybe a color to go with my choice of stripe to tie it to the outside of the car. Another paint decision.
      Thanks Ray, I was looking for another console piece to see how I liked the Z/28 one. The only thing is I already have all the Auto Meter gauges with the full sweep they won't fit in the factory style.
