    Results 1 to 20 of 23
      Frisco, TX
      Rendering: F100 project
      1st of a 2 angle rendering. The title is a little misleading. This is the 7th generation F100 platform, but really the donor truck is an F150 (stronger frame, same body).
      A hint at what we're looking at:
      C4 IFS and IRS on air ride Shockwaves
      460 bb or Twin Turboed Boss 302
      Adapted 4L60E with Twist Machine paddle shifter (1st Ford Truck)
      I was hooked once I saw them-Boze Shifters with satin black centers
      Thoughts and comments welcomed.
      Bob
      May 2007
      Houston, Tx
      looks awsome...id love to drive that thing around...who did your rendering and how long did it take?
      Colin Russ
      Frisco, TX
      Nick Crouch from http://www.surface-dvd.com/prices.htm. Big low rider influence, but great work.
      Bob
      Jan 2007
      Phx, Az
      Quote Originally Posted by Texas Bob
      Nick is a cool kid with a awsome talent! That is goin to be a sweet ride
      1973 C10,400sbc, Baer Brakes, 4 link,TOYO tires
      2010 Charger RT
      __________________
      Joe
      San Jose, CA
      That looks great!
      Tony Huntimer
      @Camaro.Family Camaros
      1986 #IROCdaily - Stock IROC
      Jan 2003
      Arizona
      That is just amazing. Totally hot! I'd lke to see you hide the turn signals behind the grille and turn the OE turn signals into brake cooling ducts.
      ________________
      Steve Chryssos
      Dunwoody, GA
      Looks good and Steves idea is not bad either. You could maybe use them for direct air intake for the turbos if you go that route. I think the truck will look great. The step side bed is what does it for me.
      Trey
      ~ Jon Hammond
      Frisco, TX
      Great idea, I'll pass that on. A soar spot we will encounter in the body is with the rear tail lights. Originally they are attached on the outside corners of the bed. In my first flareside aftermarket flares were used where the tail lights were recessed inside which made for a very clean look. From my understanding no one even makes the original fiberglass flares for this era flareside so we may go for a different option.
      Also, I've located a 3" cowl hood. Would it be too cliche to add it or leave as is?
      Bob
      Jan 2007
      Phx, Az
      Leave it as-is.
      2010 Charger RT
      __________________
      Joe
      North Jersey
      I'm a member of the FHF club (Flat Hoods Forever!). Keep the original hood and keep the competition guessing.
      Steve Ragusa - North Jersey
      2006 Infiniti G35x
      Frisco, TX
      Quote Originally Posted by TPI Monte SS
      I got a kick out of that. Thanks.
      Bob
      Snohomish, Washington
      thats really cool, someday i will do a truck like an older chevy. but good luck and keep us updated on it
      Matt
      Jan 2003
      Arizona
      Twist's Custom Shop will be glad to make you some one off taillights. Shouldn't cost much. Just provide the guts and lenses. Maybe pick up a styling cue from the wheels.
      ________________
      Steve Chryssos
      Frisco, TX
      Steve that's a thoughtfull offer I will take you up on. Thanks!
      Hopefully in the next few days we will have the rear view and have picked up the truck and dropped it off at the fabricator's. Still waiting on some measurements for Flat Out Engineering to do up the C4 bracketry. Guess I could start sourcing some parts in the mean time. I'll post up in the engine section for thoughts regarding the 2 engine choices. I'll look for your opinions there.
      Bob
      I agree no cowl. theres tons of room in the engine compartment anyways!
      the rendering looks hot by the way! I love the color.
      Chicago
      Keep it all in one place it's easier to find and it helps get the big picture of the build.
      ps - looks like it's going to be a cool project.
      marty-mj
      Lafayette
      what about some flush mount led's in the fender or maybe even the tailgate....the rendering looks awesome..cannt wait to see build pics..
      Flush mount LED's
      Scott
      Built LTX, TKO600, 12Bolt
      Frisco, TX
      Ok, so in keeping it all together I'd like to talk about the engine choice. Originally I thought about another 460 bb as you know the saying, "There's no replacement for displacement." The other option was a TT 302. I'm leaning more towards the 302 now as I think it will set the truck off...you know give it that wow factor. I could get away with a single turbo, but I'm working with an 80's truck not a flashy Cuda.
      Weight I think will be close between the 2 since there's the addition of the the turbo, parts, and intercooler. I'm not engine savy, nor am I anything but an enthusiasts so forgive me if I don't describe things more technical like. I've been looking at HP Performance's Stage 1 intercooled Twin Turbo kit for the '79-'93 5.0. I know I need to have a stout block so I'm also am leaning towards their 302 based 331 Forged performer Long Block. Ford Racing Parts has the new BOSS 302 block that was recently introduced, for the sake of having the name is this a worthy candidate for this application if forged components are used in the buildup? Another option is the 302 that is currently in the truck. I'm only wanting 550 - 700 rwhp so what 10psi so from what I've read my buildup doesn't need to be too serious as long as I replace my pistons and concentrate on my heads and cam. True or False?
      Another item that's been keeping me up at night is weight ratio. Obviously trucks are notorious for not having enough weight in the rear to keep from popping the tail out under hard acceleration. Any thoughts or proven methods to combat this?
      Finally, I've been thinking about a name for this. Always wanted a project so I could name it and a couple come to mind.
      1. Insomnia
      2. Blue Thunder
      3. Not Just 4 Show
      4. Constrictor - The bigger snake
      5. Claymore
      Still waiting on the rear view and to drop it all off at the fabricator's. Bare with me as Nick just emailed and said tomorrow we shall be rewarded!
      Bob
      Frisco, TX
      Here it is...
      Finally, both views together
      Bob
      sweet! I like how you kept the tailgate! for lights why not mount some in the rear roll pan and also some small round turns in the end of the box rails? I think its pros pick that makes them.
      Oh I also vote for the twin turbo 5.0 based motor. have you checked out www.turbomustang.com? huge forum with everything you will need
