    Results 1 to 20 of 29
    Thread: Control Arms
      Jun 2005
      Control Arms
      Can someone give a few pointers on building a set of these: http://www.scandc.com/currectrac.htm
      They don't seem to make a set for my '76 Chevy Malibu.
      I am a certified welder. I need help with understanding how those are assembled. Particularly the grease ports, and what bushings are used. These are supposed to be superior suspension parts to help with bind in a 4-link situation, so I was hoping to duplicate them for my own purposes.
      Mathius
      May 2006
      grafton ontario
      Math if you are in a buying mood the upper G bodies work and the lower 96 impala (for the swaybar) work also. mike.
      Home of the red & white money pit.
      Jun 2006
      All i have to suggest is to TIG only but beings your certified you probably you already know that
      Ontario, Canada
      Quote Originally Posted by Mathius
      Mathius
      Give Marcus at SC&C a call and tell him what you are working with. I'll bet they already have something that will fit your needs.
      Ken
      My other car is a Vega.
      Jun 2005
      Quote Originally Posted by cupcar
      I'll take a look at that. Seems like I could build a set cheaper though if I knew how they worked.
      Mathius
      Jun 2005
      Quote Originally Posted by taylorl572
      I don't mean to rant at you, but this is one of my pet peeves as a welder.
      There's nothing magical about a TIG welder. It does tend to give you better control, but a good welder should be able to run the same bead with any type of machine.
      TIG allows for better control, and it's a lot easier to switch between weld processes (switch tungsten and pick up a different rod, change your weld settings).
      Mathius
      Jun 2006
      Elizabeth City, NC
      i agree with Mathius, I can lay down a damn good looking bead (some people have thought i welded it with a tig machine) with my dillon mk torch OA setup
      Jun 2006
      Quote Originally Posted by 52deluxe
      Its not completely a matter of looks with TIG and wire feed even though i weld TIG every day i can wire feed just as good but that doesnt mean I trust it as much as TIG its a matter of the strength. Tig is a much more thourough welding process IF you do it right with a combination of rod,heat,tungsten,and gas.
      Jun 2005
      FALSE!
      I tried being polite.
      Please stop spreading false information!
      There is nothing stronger about a TIG weld than any other kind of weld. If you are using the proper filler rod, wire, whatever for the material you are working, and you use the appropriate heat settings for the material you are welding, you will get the same amount of strength for either piece of metal.
      A TIG welder does NOT make a "stronger weld" just because you're more comfortable with it.
      If this were true, they would stop making the machines that run the other weld processes.
      You do realize that an Arc/Stick welder is used most in construction? The bridges you drive over every day are held up with welds done with an Arc welder. The office buildings you go into, skyscrapers, etc. are held up with this process!
      The car you drive every day was factory spot welded and machine MIG welded!
      You're spreading false information!
      Mathius
      Chesapeake, VA
      Closer to accurate to say that MIG makes it easy for a novice welder to make a weld that looks good on the surface while having insufficient penetration and strength?
      Jun 2005
      No, if you had said MIG is an easier process and left it at that, I might agree with you. I could probably teach a monkey to MIG weld, albeit not structurally.
      But it's just as easy for someone to TIG weld a piece and have it not be strong.
      Any time you run a bead on anything thicker than sheet metal, if you haven't had formal training, or plenty of experience, then you run the risk of not knowing what you're doing and leaving imperfections, or just plain poor penetration.
      Not to mention, depending on the material you're welding, (such as cast iron for example) you could very well put down a beautifully layered weld and still have the weld literally just fall out if the piece isn't cooled properly.
      I'm not saying everyone has to go to school to be a welder, but without practicing and having some method of checking what you're doing be it a destructive test with a vise, or someone else to look over your shoulder while you're doing it, you run the risk of creating something that is unsafe.
      And it has nothing to do with the type of welder.
      TIG has become a very preferred method of welding because it allows total control. You control the amount of filler rod added. You control the amount of heat with your foot pedal. You can also get into a lot of places with a TIG that a large MIG nozzle won't fit into.
      But for these same reasons, it's harder to learn how to TIG, because you have to learn to use that control you're being given. That's why TIG welders generally get paid more. (although nowadays almost everyone requires you to be able to use all processes)
      Somewhere along the line, someone figured out the "elite" welders were using the TIG welders, and that a TIG setup costs twice as much as a MIG, and they decided it makes for a better welder.
      I'll say it again. Given that heat settings, filler material, and base materials are equal, you can do the same thing with a MIG that you can do with a TIG, and get the same results, and the same amount of strength.
      There is nothing special about a TIG welder that makes it stronger.
      Mathius
      Jun 2006
      Elizabeth City, NC
      lay it down Mathius.......
      Jun 2006
      Torrington Ct
      Each process has its place . If you think your going to weld a intake manifold ,intercooler or 16gauge piping with a spoolgun and end up with the same product now thats a false statement !
      Jun 2005
      Quote Originally Posted by FabUThis
      I guarantee you you could with enough practice. You could do it with an acetylene torch and get the same results with the proper flux and control.
      Stop saying things are impossible just because they are hard.
      Aluminum is harder to weld than steel. It tends to go from solid to mush quickly and doesn't change color much unlike steel.
      I'm telling you as someone who is certified on 1/4" aluminum and stainless in TIG that even as a certified welder, I still find it difficult to weld aluminum for _structural_ purposes. It's just damn hard to tell what kind of penetration you're getting without an x-ray or seeing the other side of the material.
      It's easier to weld aluminum with TIG than anything else, again because there's more control over the heat, and that gives you a big advantage when welding aluminum.
      But it's still possible to do it just as effectively with another process. With MIG, you'd have to have a big machine to do what you're challenging me to do, but it could be done.
      Unless you're just telling me there wouldn't be room to fit the spoolgun in the required space, which is a possibility. But otherwise, it's doable.
      Mathius
      Jun 2006
      Torrington Ct
      I get it your CERTIFIED welcome to the club .I didn't say anything about being impossible . You said you would get the same results from a MIG not a torch . Make no mistake I'm not challenging you to do anything . If you want to waste you time trying to weld 16 gauge tube with a spool gun have at it .
      Good luck on your control arms you seem to have all the answers they shouldn't be a problem for you .
      Jun 2005
      The way I'm reading that, it sounds like you're saying that if I say it's possible for someone to do that, then I'm lying or otherwise incorrect.
      I can, but you're reading it wrong. I didn't say use a torch, I said you can do it with a MIG or a torch. Either method will work. TIG is going to be easier, no doubt.
      For a guy who already has a $700 MIG and a spool gun, it isn't a waste of time, if he has to put out another $2k to buy a TIG.
      If I had all the answers I wouldn't have posted in this forum. All I was trying to say is I'm a competent welder, so I'm not lookin for welding help, or someone saying it's too hard.
      I need help with the fabrication side of it because I don't know how these things are assembled, particularly where the bushings are installed, and how the grease ports work.
      If you're going to post a contriversial (and challenging) statement like you did, you should expect to get called out for it, so don't get upset with me because I said you were wrong.
      Mathius
      Jun 2006
      Torrington Ct
      Sorry for hearing it wrong .
      Jun 2006
      Torrington Ct
      It's not upset that I'm wrong its that I spent so much money on a TIG I guess I didn't need .
      Sorry again don't know want I was thinking .
      Fab-U-This / another competent welder
      Jun 2005
      <shrug> You probably don't _need_ it, but it's definately going to serve you better than any other welder. It's a lot easier to TIG aluminum than with a spool gun (as we already said). You can also weld just about anything with a TIG with the right tungsten and filler rod, from stainless, to aluminum, to exotic metals like brass (lots of fumes, wear a ventilator mask) or bronze.
      As I already said, it gives you more control too. Personally I'd love to have one.
      I freely admit I'm not as good with a MIG as I am with a TIG, but it's because I don't have a lot of respect for MIG, so I never spent much time with it, except now that I can't afford a TIG, I rely totally on my MIG.
      Mathius
      Jun 2006
      You definately did NOT waste your money on a Tig, dont feel bad at all TIG is far more versatile than any other welding process. When i started welding it was with a mig and eventually i decided i wanted a tig so i bought a miller syncrowave 200 i recently water cooled it and i love it. sure I still use the crappy,dirty wire feed for non structural stuff like benches, racks and sheet metal patching. but other than that I TIG. Even at one of my jobs where i finish weld motorcyle frames (Twisted choppers) we tig the frames only theirs no way we would wire weld a customers frame. So basically what im trying to say is dont regret buying a tig for one second they are the Sh*t.
