    Results 1 to 11 of 11
    Thread: LS2 Wiring
      Colorado
      LS2 Wiring
      Has anyone used the Painless LS2 wiring harness? I am buying an LS2 crate motor. The Painless manual says this. Has anyone done these modifications to make this harness work?
      If you have purchased an LS2 with an engine code other than those listed above, you can still utilize this
      fuel injection wire harness after these engine modifications are made. Contact your local engine machinist
      shop for help with these modifications.
      1. The 58X crank shaft sensor reluctor wheel must be replaced with part number 12559353. This
      replacement part number is a 24X crank shaft reluctor wheel from a 2005 Corvette LS2.
      2. The crank shaft position sensor must be replaced with the part number 12560228.
      3. The 4X camshaft sprocket must be replaced with part number 12576407. This is a 2X sprocket from a
      2005 Corvette.
      4. The cam shaft position sensor must be replaced with part number 12568983.
      68 Camaro
      LS2 6speed
      Complete Hotchkis front and rear suspension, Global west SFC, 3rd gen steering box, C5 front rear discs w/ 4th gen booster and MC. 8.5" posi rearend with 30 Spline 12 bolt axles.
      Jul 2003
      Anaheim Hills, CA
      Oh forget that.. switching the reluctor wheel is a MAJOR PITA.. and expensive. also, did I mention what a pain in the ass it is? Who wants to tear apart a perfectly good crate engine to do that?
      If you have a 58x engine (chances are that you do) then use a harness/computer designed to work with it.
      I would reccomend Speartech fuel injection.. http://www.speartech.com/
      Tell him that guy from Popular Hot Rodding sent you..
      1968 Track Rat Camaro:
      Colorado
      Thanks for the help and saving me the headache. The speartech stuff looks nice but that $2000 price tag is a little harsh. Any other ideas or slightly budget friendly ideas.
      68 Camaro
      LS2 6speed
      Maryland
      I can't beleive that someone hasn't figured out how to reprogram the LS1 pcm to use the 58x reluctor ring,or possibly made an interface module to convert the info to the old pcm
      Jul 2003
      Anaheim Hills, CA
      Quote Originally Posted by Midnight68
      If you supply your own harness it's much cheaper..
      Try Turn Key Engine in Oceanside CA. They have a 5-wire deal that uses the GM marine computer. I bet it's a LOT cheaper but it is less capable compared to the normal computer.
      You can buy the harnesses and computers on eBay as well and then have them reworked
      Oct 2006
      Speartech seems like a total package.
      Does S&P (www.hotrodlane.cc) offer the same for roughly the same price?
      • '70 Mercedes 280SL (wife's)
      • '55 Nomad
      • 71 BMW 2800CS
      • '06 Chrysler 300c SRT8 (wife's)
      Jul 2003
      Anaheim Hills, CA
      Very happy with my Speartech harness.. wiring was super easy.
      Oct 2006
      Quote Originally Posted by Steve1968LS2
      I notice that the Speartech for 4L60E comes w/a trans controller.
      Know if it'll (controller) work w/the SHRIFTER???
      • '55 Nomad
      • 71 BMW 2800CS
      Jan 2007
      harness
      Check with these guys. They might be working on it. I have used 2 of their harnesses. First rate stuff.
      http://www.howellefi.com/shop/custom...cat=253&page=2
      Jun 2006
      Indianapolis,IN
      Howell, Builds Turn Keys harness for them.
      Tim
      Quote Originally Posted by ragtopdodge
      No.
