Results 1 to 20 of 53
Thread: G-Body Guys, Wheel Fitment
09-13-2006 #1
I am trying to figure out the widest wheels I can run front and rear. It is kinda hard to measure since my car is torn apart and rideheight is not yet set.
I am going with 18's. I have a frame notch in the rear, and tubular UCA's and LCA's in the front.
HOW WIDE?
Jeff
JEFF SHORTT
-IDEAL STEEL
09-13-2006 #2
- Aug 2004
- Rowlett Tx.
- 201
Kind of depends on the actual ride height. For sure you could go w/some 18x8's up front & 18x9.5's out back (w/a frame notch) w/o having the tires stick out past the fender-lip.
For rubber: 245-40's up front & 275-40's out back. That should help keep the suspension planted.
09-13-2006 #3I'm running 18x8's front b-body spindles and global west arms 4.75" backspace 245/40 (5" would have been better) and 18x10's rear 5" backspace 275/40.....no frame notch yet..slight roll of the lip. when it needs tires again its getting notched and a set of nitto 305/45's (maybe with a little more sidewall flex I might gain some semblance of traction lol)
the 9.5's I had on the front were a set of vette 17's that I used a set of billet spacers to mock up....they are to much for a "driven" car ...i.e. I saw lots of rubbing in the future....I can't remember the exact backspace as its been about 8 years ago I did that...sorryMatt
1980 Malibu, off the jackstands.....let's see if a T-56 will last longer than a TH-700R4
09-13-2006 #4GBody,
I run a 17X8 TTII 4.75 BS Global west upper arms with
a 245/45/17 BFG KDW's Rears are 17X9.5 TTII with 5.00
BS With 275/40/17 BFG KDW's.Iam running UMI performance
rear lowers and uppers (control arms) rear swaybar,and
the rear fender lips are rolled.I don't think you will have
any issues with 18" or even 19" wheels.I just purchased
this little tool for wheels.Not bad for $99.00 bucks and
will help me in future wheel/size projects and takes allot
of guess work out of wheel/tire sizes..at least i think so.
Good Luck,
Here is a link...
http://www.percyshp.com/producthomewheelrite.html
10-23-2006 #5
- Nov 2002
- Finland
- 209
Do you think a 18*8 with 4.5" BS would work at all in the front? I have a stock setup minus hotchkis lowering springs and belltech spindles(might change back to original)
Originally Posted by RatMalibu
Chris
10-23-2006 #6
