Results 1 to 9 of 9
Thread: Help Help Help!!!
03-05-2006 #1
Help Help Help!!!
I was just jumpering teh underdrive pulley pins on my DC controller to give a constant 10% minimum current, when I started the engine the fan did not turn at all, (may be the way I have the DC Controller wired, however the BIG problem I noticed was that my upper radiator hose was being collapsed, as if there was a blockage or something and the walls of the hose were being collapsed. I shut down the engine and checked the radiator fluid level and it was about 3 inches below the cap level (the engine was cold). So I filled the radiator to full and I wanted to see if anyone knew why this might happen before I start the engine again. Problem is I have to leave for a 4 hour trip in this car in about 5 hours, so I am in need of some seriously fast assistance. Thanks.
-George
03-05-2006 #2
if it was collapsed right at start up it could be that maybe there was a vacuum in the system after the car cooled last time u ran it? and the air in the system contracted?
03-08-2006 #3
George, exactly how do you have the controller wired? There shouldn't be any confusion but I'd like to know and see if I can help you out. -Jabin
Gmachinz Sales and Performance
"updating the level of performance..."
[email protected]
*never argue with an idiot-they'll drag you down to their level and beat you with experience!*
03-08-2006 #4
New to Pro-Touring
- Feb 2005
- Crooklyn, NY
- 74
From the DC website:
Underdrive
If underdrive pulleys are installed and the vehicle is prone to overheating at idle, a jumper is provided (13,14) to render a 10 % minimum current to the fan whenever the ignition is on in order to aid in convection flow. The ignition input wire must be connected to use this feature.
what temperature are you seeing? Do you have any other jumpers installed? What temp does the fan turn on?
I took the restrictor plate off to give the Red Dragon a little more Juice. But keep that on the Down Low, it's not exactly street legal.
http://community.webshots.com/user/strokermotor
03-09-2006 #5Do you have the IGN wire hooked up to the controller or only the BATT wires?
Dustin
04-01-2006 #6i have the DC controller wired as shown above, except I have the power wire going to a battery junction block (battery was relocated to trunk) and I have the ground to a chassis ground, and I have the surge protector installed across the positive-negitive terminals of the DC controller. I think I may have found the problem but need help with the solution. You see I have a Be Cool radiator (for manual trans) and a catch can that is not vented. As soon as I start the engine the top radiator hose collapses, if I shut off the engine the hose remains collapsed, when I open the radiator the hose returns to normal. I think I need a vent somewhere in the system, most likely in the catch can, but how do I do that, there is only a petcock on the bottom of the catch can for draining it, but no vent. Any ideas would be appreciated.
-George
04-04-2006 #7Gmachinz Sales and Performance
[email protected]
04-05-2006 #8
- Aug 2001
- 924
