    Page 1 of 6 1 2 3 4 5 6 LastLast
    Results 1 to 20 of 110
      new zealand
      second attempt max-g69
      problems on the first attempt hope this works car runs 500inch big block/tko600/19-12rears19-10front no front brakes yet any sugestions hope to run 9s previous best 10.1cheers darrin
      Jan 2003
      Arizona
      Full frame cars are awesome. You can get the ride height way down and the stance perfect without hindering suspension geometry. Something as trick as that SHOULD require a lot of work. Keep it up. That looks hot.
      ________________
      Steve Chryssos
      Burnaby, BC, Canada
      Your project looks really sweet, keep us posted.
      1969 CAMARO RS
      Project pics of my '69
      Lateral-G Feature Page
      Batesville, IN
      Max G
      Are you welding the frame into the unibody or making mounts to bolt it on. Just curious, I'm considering a Max G for an early body Chevy II (after my current project and money permitting).
      I'd love to see some more pics of the frame install.
      That car should look Bad-ass!
      Brandon
      Brandon Wiedeman
      1972 Suburban
      Wiedo's
      Morgantown, WV
      How much to finish and ship to the states?? That thing looks awesome so far. What color combo are you going to go with?
      Rich Shinkovich II
      Bowtieguys
      S3 "BAD NEWS" 67 Chevelle SS
      Mar 2003
      Make it big
      That looks so sweet man!!! What size tires are you running on those 19's?
      -David
      new zealand
      thanks for the replys i have gone for the weld in just seems a lot easyer and stronger paint colour will be the same black just touched up at this stage,the car will run at 5inchs ground to pinch rail,anyone intrested in the cost of parts in new zealand rear tyres 1400each!!no burnouts on those i think some second hand tyres are in my future do they turn up in the states?
      new zealand
      rear tyres measure 345/30/19 looks a bit strange with 19s on the front is this why most go with smaller wheel on the front?
      Mar 2003
      Make it big
      I don't think it looks werid, the 19's all around look really good
      -David
      Jun 2002
      Benicia, CA
      Holy Cow, $1400?!?!
      Quote Originally Posted by hiwayman
      Is that $1400 each, or for both tires? US dollars? I got my new 345/30/19's from Bones Enterprises on Ebay for a little over $300 shipped for both tires, so I feel lucky. They turn up used on Ebay every so often, keep on the lookout.
      Awesome car! Post some performance numbers when you get to drive it hard. I am interested in cornering performance (g's) and braking distances with the big tires (I have 19x13's rear and 19x10's front).
      Jeff
      1971 RS Camaro: PAINKILLER
      Vancouver, BC
      looks very nice!
      new zealand
      max-g
      hey got the car out for some sunshine
      Holy cow. You are really moving along with your project. Looks nice. Still picking away at mine. Finally got the inside of the outer rocker panel painted this weekend with the epoxy primer. If everything goes right I hope to be welding in the custom inner rocker panel I made to the stock/modified outer rocker this weekend. Still lots of prep ahead. I hope to have the body on a rolling chassis by the end of april. Chris
      Aug 2003
      Looks sinister. Can you shot a pic or two inside showing how it mounts to the rockers and such?
      Hiwayman can you tell me how you determined engine placement in the chassis. This is one of those things I have no idea how to do. Is there a certain angle the engine needs to be tilted back? Thanks Chris
      Jan 2003
      Arizona
      Awesome.
      ________________
      Steve Chryssos
      Mar 2003
      Make it big
      That stance with the 19's look so sick!!!
      -David
      El Dorado Hills, CA
      That is awesome!!!!
      Brad
      68 Camaro - Procharged LQ4 coming - Currie 9" narrowed, bagged, lays frame, BMW projector HID's LED tails, 18"s, lexus center console, seat warmers, A/C... Mini-tubbing in progress!!
      07 BMW 750li -loaded
      Jul 2002
      Muskegon, MI
      I saw this car on the Lateral G site and fell in love with it instantly! What a bad a@# looking ride. You said that car has a morrison max-g chassis channeled 4inches with 5inches to the pinch rail right?
      The wheels match the car perfect!
      Jun 2003
      Chicagoland
      That looks great.
      W.
      William Rouleau
      Project PonySnake - '67 Mustang Fastback
