    Page 2 of 6 FirstFirst 1 2 3 4 5 6 LastLast
    Results 21 to 40 of 110
    1. #21
      Nov 2001
      Sacramento Ca
      Those are ROH modenas right? Love those wheels.
      Awesome project.
      Tony Langlois
      1966 Corvair Monza
    2. #22
      new zealand
      how it mounts
      hi chris i see you went with the epoxy i used it to prime chassis as for the engine angle im not sure myself iv just finished an engine plate without the mount tags so can someone answer this, engine angle?I read were you are going to bolt the chassis in? tony wheels are modenas i painted the centres they had that silver fininish on them yea the black is nice.camaroboy yip 5inchs to the pinch rail .
    3. #23
      Wow the pictures of the frame and welding directly to the body blew my mind. That is awesome but permanent. How did you know exactly where to place the frame in relation to the body before welding? In your picture it looks like the rearmost crossmember is not at the beginning of the wheel well in the rear as I thought. Did you mount your wheels on the rear axle and center them in the rear wheel well? Thanks for the help. Your project is 10x farther ahead than mine. If I knew how to post pictures I would definately be shooting and posting. Looks awesome. Chris
    4. #24
      Nov 2001
      Sacramento Ca
      you can use our very own "manage attachements" button and host them here. (but youre limited to how many)
      or you can go to www.imageshack.us Follow the prompts, its free, no sign up and limitless and super super easy for the beginner. It even makes the code for you, all you do is select the image, click "host it" and then copy and paste the code it makes for you.
      Tony Langlois
      1966 Corvair Monza
    5. #25
      Jun 2005
      That looks mean! I love it. You can always make some extra tire money by renting it out as a steam roller!
      Jim
    6. #26
      new zealand
      hey chris yea centered the wheels in the wheel wells also squared car inrelation to the diff only have a few tacks weld holding in at the moment,the fit bettween rockers and chassis was perfect i would say the bolt in deal will be a lot trickyer i have no need to pull it out ,starting floor this week yea get some shots of your ride up cant wait to see it .
    7. #27
      Nov 2004
      Forney, TX
      First let me say that your car looks killer, but are you really going to mount the body this way? You must have complete confidence in your welding skills, because I couldn't trust myself enough to do it.
      __________________________
      Boyd
      1972 P/T Style Chevy Short-bed - coming soon
      Specialty Auto Services
    8. #28
      Nov 2004
      NW Arkansas
      Quote Originally Posted by Boyd
      I bet he is not done welding!!!!!
      KENNY DAVIS HOTRODS
    9. #29
      new zealand
      not to sure what the last comments meant but the welds shown are just tacks holding in position,the body shell will be held in by stitch welds say 50mm spaced every 20mm,also the pinch weld will be tig welded to the chassis how would you guys do it? i know kamaroman is bolting in .
    10. #30
      Aug 2003
      Looks killer. You are very accomadating providing pictures. Isn't it fun building something different? I would like to see a interior shot accross the interior showing the inner frame and seat location.
    11. #31
      new zealand
      hey prodigy no seat location as yet i would like to no your opinion on how the frame is attached ,what im realy asking is how would you guys do it thanks darrin
    12. #32
      Aug 2003
      We did exactly what you are doing with Prodigy, but your fit up does look like a bit too much of a gap. Your gap should not exceed the thickness of the thickest metal, in this case, 1/8" for the frame rails I assume. I would consider plating the top and bottom to the rocker with possibly 3/16 plate. Don't worry about weight here, it is good weight. And if you have a rotisserie available to get a better welding angle on the bottom, that would be ideal.
      I really love this frame, in fact we drove the 55 we are finishing just Saturday for the first time, and it seems pretty killer on the maiden voyage. I do have major seating concerns though in Camaro's. I wondered if you cut out the rails running from the rocker rail to the center rail, or if you are mounting on top of the rails. I see in Bob's Cuda and Parson's Chevy 2 they basically removed the center supports. I will be curious to see where an what seats you use, and if you have any head room.
    13. #33
      Nov 2004
      Forney, TX
      Quote Originally Posted by Travis B
      Ya, I know. But that is still a big gap to fill in and even with the metal doubled over at the rockers, it's still scary considering how much penetration is needed for a structurally sound weld. Frank's idea about "wrapping" the rocker and the frame with plate sounds like a good one though.
      Boyd
    14. #34
      new zealand
      hey frank thanks for the reply, man talk about a panic attack ,straight down to the shed for a inspection,the gap is about the thickness of a steel rule in about 30% along the rockers and touching on the rest in your opinion is this enough ?the seats will go straight to the floor or maybe resses the seat rails thanks again darrin.
    15. #35
      Aug 2003
      Like I say, the gap should be about 1/8", no tighter, no wider. I would still consider the plating.
      Look forward to somemore pics.
    16. #36
      May 2001
      Mesa, Az.
      Darrin-
      Was just wondering about the progress. Did you decide to do the plate or just weld it straight in?? Phillip
    17. #37
      Farmington Hills, MI
      CAR LOOKS GREAT MAN. I LOVE IT
      Jeff
      JEFF SHORTT
      -IDEAL STEEL
    18. #38
      new zealand
      hey phillipM have not welded it in yet pretty sure will plate it though,floor and tubs are in will post some pics soon computer dramas thanks jeff
    19. #39
      new zealand
      floor
      just a few shots of the floor install
    20. #40
      Batesville, IN
      Back Seat?
      It doesn't look like you are going to run a back seat, but is there enough room for one if you wanted to? Just curious.
      Looking good!
      Brandon
      Brandon Wiedeman
      1972 Suburban
      Wiedo's
