    Page 2 of 2 FirstFirst 1 2
    Results 21 to 28 of 28
    Thread: Ridler 652
    1. #21
      Math is hard!
    2. #22
      Mountain Springs, Texas
      6.5 - .5 = 6
      1957 Buick Estate Wagon
      1959 Apache Fleetside
    3. #23
      I'm going to take some measurements tomorrow. I have the body off the frame so can't check the fender clearance, but I can see what it looks like to the frame and suspension.
      Maybe i could run those 9.5's with the 5.25" BS and use a 265/35 tire. That would be almost half an inch narrower than a 275/35.
      Also my factory front inner fenders are pretty rough, so I wouldn't mind doing some modifications to them to help gain some clearance.
    4. #24
      Quote Originally Posted by gtome View Post
      Fender clearance will be your issue with those wheels and backspacing. You will likely be contacting the wheel lip unless you run a lot of negative camber or your ride height is sky high.
    5. #25
      Bummer. Oh well, I guess an 8" it is. Not a huge deal really. I was just hoping to have a wider wheel so I had the option of running a 275 out front if I wanted.
    6. #26
      Put a 275/35/18 on the frame today. Just to get an idea what I was looking at. This one is a 9.5" with 6" BS.
      Turns out I don't love the wheel with that much back space. From most angles you can't even tell the tire is wide. This is the car I pulled the wheel from.
Size:  448.4 KBName:  20241021_183018.jpg
    7. #27
      Well 305's for the rear aren't looking possible either. Like I said I have the body off the frame for another week or so, so I can't get a super accurate measurement. I bent a 12" wide aluminum rod today to simulate a tire. I was hoping to run the wheel just to the bottom of the high part of the rear wheel openings. In that scenario, it looks like i would only have 2-3" of travel before it would hit. I can massage the outer wheelhouse some, but I don't know if I would get enough to make it worth it.
    8. #28
      The 305/35r20 is super tight in there. I may try to roll the lip and see what that gains me.
      The first one is about where I want it for rife height, and the second is about where it hits the lip. Not more than 2" of travel there.
