    Results 1 to 14 of 14
      Feb 2022
      Rear end options
      I currently have a '69 Firebird with LS2, T-56 McLeod RSX twin disc.
      looking for some direction on rear end upgrades.
      I currently have a stock 10 bolt with GM limited slip diff and 4.10 gear.
      Discovered I have a slightly bent axle at the hub end.
      My plan is to supercharge the engine and get to 600 rwhp range.
      I could get by just swapping out the bent axle,but ultimately will need forged axles a stronger diff and a more suitable gear ratio.
      Should I even bother with the 10 bolt,or just upgrade to a 9" now?
      Budget is a bit of a concern as I will likely spend $6k on a LSA blower upgrade.
      Anyone know of any deals on a lightly used built rear end?
      Feb 2019
      Easley, SC
      My opinion, do a 9".
      If you don't go crazy, you can get one for like $2800-3800, all new.
      If you're not tracking the car, a 10 bolt will suffice with that power.. But, C clipped rears aren't worth the money unless you find a deal on an already modified one or something.
      -Dale
      Pro Touring Store: Your parts source for all things Pro Touring! We have the best prices & service from suspension, to crate engine packages, to billet accessories and much more!
      www.ProTouringStore.com
      (Not affiliated with Pro-Touring.com)
      Mountain Springs, Texas
      Maybe an 8.5” 10 bolt? They are getting rare but still out there if you are patient.
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Oct 2015
      Quick Performance 9" - best bang for the $$' 10k on mine with zero issues.
      My half a$$ed build thread.https://www.pro-touring.com/threads/...elle-6-0-4L60E
      Tighten it till it strips & back it off a quarter turn.
      Feb 2022
      Don
      I currently have an 8.5" corporate 10 bolt,GM limited slip diff,and 4.10 gear.
      It has been painted with automotive quality gloss black paint and has a T/A performance billet cover with pinion brace.
      Maybe I'll just upgrade/replace the bent axle and hunt for a used "built" 9 inch in the meantime??
      I just missed out on a Currie 9 listed on here a month ago for $1000.
      Feb 2012
      Vancouver,Canada
      Harleydave I'm running an 8.5 10-bolt in my 69 Camaro. Also a GM limited slip.Upgraded to Moser axles,T/A Performance billet cover. 3.90 gears with 406 SBC making 450-460 at crank through a T-56.If you're putting big horsepower down the Ford 9 is the way to go. If you track the car definitely Ford 9 but some spirited street driving that 8.5 will take that all day long.Been running this setup for 7 years now without a blip...
      Feb 2022
      Quote Originally Posted by Dave Pratt View Post
      Thanks,I decided to just replace the bent axle and drive it for a while.
      I'll probably upgrade to a 9" with a 3.50/3.73 gear when I upgrade to the supercharger.
      Dec 2010
      Fredericksburg, VA.
      9" hands down. You can buy a Moser Engineering full floating axle rear end starting at $2876. I actually wish this package had been available when I was building Dust Off it would have saved me a lot of time and fabrication headaches.
      https://www.moserengineering.com/9-F...d-Package.item
      Depending on your T56 OD ratios you will want to rethink the rear end gear ratio. I'm running a T56 with .74 5th and .50 6th OD ratio, I have a 3.89 rear gear and it works great. I could also see where a 4.10 would work as well since I rarely get into 6th.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Feb 2022
      My LS2/T-56 is from an '05-06 GTO.
      Looks like it's a 2.97 1st gear with a .057 6th gear.
      Currently running a 25.7" rear tire with 4.10 rear gear.
      1st gear is very short and almost useless at WOT.
      I can only imagine what it would be like with an additional 150-200 hp.
      Mar 2020
      I've had good luck with Strange Engineering.
      They make 12 bolts, 60's & 9" rears to suit your needs.
      One nice thing you can do is ask for the Mopar style leaf spring brackets, instead of the U-shaped GM ones.
      Pair this with a set of Caltracs & U-bolts & you have a good combination.
      I cringed when & saw the 2.97 low... with a super charger, you may be better off with 3.42's or something similar.
      I just removed my 4.10's when I supercharged my LS3 & I have a 2.66 low with 27.5" tires.
      I needed 5th gear in the Quarter & traction was always an issue in 1st.
      The 3.54's are way better. (lowest numerically you can get in a S60). Thats an equivalent of 2.92 gears with your tires/1st gear trans ratio for comparison.
      Dec 2024
      I would absolutely go with the 9 inch. So many advantages. I have a brand new currie 9 inch with their pro touring fabricated housing and the baer tracker floater setup on it. I most likely will not be using it on my build as was previously planned so it may be for sale.
      Feb 2022
      How much would you need?
      Bolt in to Gen 1 F body?
      Dec 2024
      It's a raw bare currie F9 fabricated housing with the baer full floater kit welded on by currie at their shop. I have 13 inch baer ss4+ brakes on it as well. If you wanted just the floater housing I would do 3k with brakes 3500. I also have a very nice strange aluminum center with billet caps and a Tru trac diff and 3.25 gears. Brand new setup never run. Set up for 35 spline axles. It'll take 1000+hp no problem. If you want that as well we can work something out I'm sure cause I would want the whole setup to go together.
      - - - Updated - - -
      All parts are brand new and were just used for mockup
      Mar 2022
      Florida
      9 inch fosho, love mine.
