      Oct 2017
      Current E-67 GMPP PWM programming?
      Does anyone know if the current E-67 ECM's from GMPP contain the pwm programming? As it comes out of the box, its set up for one fan on/off at 207 degree on a 30 amp fuse/relay. I would like to run one or two pans thru PWM if its not a lot of work. Aftermarket controllers are my second choice but using the OEM control and existing engine water sensor would be best.
      Quote Originally Posted by GTO Jack View Post
      There are a few details here:
      https://lateral-g.net/forums/showthread.php?t=59543
      Oct 2017
      I read a lot of those forums before asking here. You find some say yes, some say no and no one that is sure because I think it was in the ECM for a while but now is not. I think I will just go with a aftermarket version and I know it will work.
