    Page 3 of 3 FirstFirst 1 2 3
    Results 41 to 60 of 68
    Thread: Tremec TKX
      Jul 2018
      Any updates on these?
      Quote Originally Posted by Just 1 More View Post
      They are shipping...I've seen a few installs on other forums.
      Jul 2017
      Island Lake, IL
      I really like that 17722 GM gearing. Nice.
      Nov 2007
      Melbourne FL
      i ordered a 18083 on jan 11 and im still waiting. looking forward to it showing up.
      Quote Originally Posted by TrendSetter View Post
      Name:  screen_shot_2020_11_05_at_3_56_42_pm_31600ed1c8b20f17035195aeca2fa3e400eb4376.png
      CA
      Anyone using the Tremec TKX ... How good is it?
      I'm curious to see reviews of the new Tremec TKX. I swapped out my Mustang's toploader a number of years ago to a Tremec TKO 600 and have found it okay but didn't think it shifted as well at higher rpm. My friends thought it odd that I had any complaints about the TKO but now I see this TKX addresses the "problem" that I had never seen any reviews about ... the TKO's don't shift well at high rpm ( finally something that confirmed my suspicions ). I'm still running a T-10 in my '62 Corvette and have not changed it to a 5 speed yet, but the articles also state that the TKX is slightly more compact (?). Is that true?
      Sep 2007
      I thought the TKO's shifting problems were pretty well known. It's not happy at much beyond 6000 revs. Some guys have gotten them customized to work at 7000+ revs. Other guys were never happy with it at high revs even after getting it reworked.
      Chicago suburbs
      Finally had a chance to drive this TKX. Ended up reworking my exhaust too, but that's another story. I tried to make the comparison as "apples to apples" as I could. I only swapped the trans, everything else stayed the same. Previous trans was a TKO600 with a spec clutch behind an LS3, with a hydraulic clutch. I was only able to get about 4deg of driveline angle which was too much.
      Swapped in the TKX, and the 1st thing I noticed was that now I can get 3deg. That doesn't sound like much, but it means the trans mount is about 1" higher. Headers now fit better too. Everything else lined up exactly like the TKO except the neutral safety switch.
      Filled it up with RP syncromax fluid and went for a drive. Shifting is WAY better even at low RPM. Really crisp & precise. Downshifting is better too, this trans is fantastic!
      Thanks for the review. I am super excited to get mine installed.
      Aug 2013
      Shelton WA
      Now I'm torn. Do I install the brand new in the box TKO600 or take the hit and order a TKX.
      Quote Originally Posted by SPLATT71MC View Post
      Take the hit..
      Chicago suburbs
      Agreed - although I will probably hang on to my TKO. I like it, a good trans, but nowhere near the same as the TKX.
      It's almost like comparing an LS to a SBC. Seems like they got it right this time.
      May 2007
      Las Vegas
      Does anyone have pictures of where the shifter comes through the tunnel in a 69 Camaro? I think there's thee positions built into the design? I don't have a console and will probably do something custom later on. I'm starting with a auto/column car so nice clean tunnel …
      Rich
      1969 Camaro (in hibernation)
      Jul 2018
      What's the latest on the TKX? Has it lived up to the expectations?
      Jan 2020
      I'm liking mine. Went from the TKO 600 to the TKX. I only have 100 miles on it, but I can tell you it fits the tunnel much better which means better pinion angle and exhaust clearance. Haven't shifted it hard yet, but I never had any shifting problems with the TKO so I'm sure that's fine.
      Red Deer, Alberta, Canada
      For the guys with the TKX installed, what length of shifter are you running? I hear the shift throw is quite a lot with a shifter over 6" long.
      Matt
      Instagram: Cst_koon
      Jan 2020
      Quote Originally Posted by protour_chevelle View Post
      I have a 10" handle and the throw is shorter than my TKO 600 with Pro 5.0 shifter and same handle.
      Jul 2018
      How would you compare the throw to a Muncie?
      Jan 2020
      Much shorter than a Muncie.
      Jul 2018
      Quote Originally Posted by smax View Post
      Good to know, thank you
