Results 41 to 60 of 72
- Apr 2007
- 193
I'm reading, watching, but off the top of my head pre morning coffee, I don't have much input.
Thought experiment- what happens if you go to a stiffer front spring, and hold the car-as-a whole, flatter with that. Theory says should increase push, right? What if it doesn't actually do so in practice? I think your odds are better than 50-50.
Can you explain your taking out the .9" tall balljoint in favour of a .5" tall one? I trust you give your set up much more thought than I can just walking in here, but it is also true that you felt (and I agree) that that meant a need for more static neg camber, and also that you now note the outer tire is in need of more neg from somewhere ( maybe caster is a last grasp option?). Basically, in following the saying, "you don't understand something fully until you have to explain it", can you throw out a few sentences on what change in feel you aimed for, and consider if you got it?
I'd have lowered the front end at that point- cut say a quarter of a coil off- you'd change the turn in, get your rear end looser, and get deeper into the camber curve. Not by large amounts of any, but all factors are directionally the same so add up. That is definitely "hack"..., but this is a car that despite all the work and thinking we do in this "niche" of performance, has only a fair to middling and largely unchangeable geometry set, by definition. At an OE or custom suspension level, I think playing with rear roll center at that point might have helped, so what do you have you can do with stock rear parts? I'm not a Camaro guy- you do have a panhard bar in these, right?
