    Results 1 to 12 of 12
      Sep 2019
      Oil catch can setup
      Hi I have question about catch can setup
      I have L77 engine that looks like the picture
      is this setup and cap the nipple in back of driver side valve cover will work with other catch cans ? (I got this picture from the internet)
      Also can I instead of using oil breather cap use this small filter with the nipple in the valve cover marked red in picture?
      Pensacola, FL
      I have mine plumbed as shown in your pic. I do not have the breather though, just the stock style threaded cap. I drilled & tapped a plastic 3/8 barbed elbow on the bottom of the intake tube, just in front of the throttle body.
      Jun 2010
      Deployed
      The PVC is supposed to be sealed. Fresh air is drawn in from the intake tube (metered) to the valve cover, sucked into the intake system from the valley. If you draw non metered air through a breather, it will not run right. All air entering the engine should be metered by the MAF sensor.
      Quote Originally Posted by Z06vet View Post
      1970 Camaro/DSE build
      Jacksonville, FL
      Mine is plumbed exactly like the picture and Scott’s. BA81z28, the air from the intake tube is post MAF sensor. Mine runs perfectly fine, 13000 miles and no issues. I have had a couple of different intakes on it but they were plumbed exactly the same. Here is a picture of mine.
      Chris
      1968 Chevy Camaro SS
      LS3/4L70e, DSE suspension
      Sep 2019
      I have maf sensor delete tune also my throttle body is adjusted I increased the idle because of performance cam shaft that I have. so I don't know if the catch can will work well if i connect the clean side from to the throttle body to the valve cover with the adjusted throttle body
      Jun 2010
      Deployed
      Quote Originally Posted by 130fe View Post
      Yes, the air being pulled from the intake is supposed to be post MAF. Looks like yours is plumbed just like mine. Sealed, no breather to open unmetered air.
      Oct 2007
      SO in these examples.. is the drivers valve cover vent tube capped?
      67 Camaro In progress
      Jacksonville, FL
      Yes, my drivers Valve cover tube is capped.
      Chris
      Oct 2007
      Camas, WA
      The hose coming from the passenger valve cover is connected to the intake tube or some other place?
      Mountain Springs, Texas
      Quote Originally Posted by 68EFIvert View Post
      To the intake tube between the MAF and throttle body so the air is metered by the MAF.
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Oct 2007
      Camas, WA
      Thanks Don. If I don’t have a MAF just run it into the intake tube/box?
      Yes speed density you can connect to any source of clean air.
      Don
