    Page 3 of 3 FirstFirst 1 2 3
    Results 41 to 55 of 55
      Jun 2017
      Edgewater Co.
      For those interested, I just made a video (part 1) covering the basics of the Terminator X software.
      If you find it useful, please like and subscribe and I will make more.
      Thanks for your efforts with the Terminator X, when It first came out, I saw it as the solution for a couple of my projects... with this info and info and parts being provided by Michael Noonan of EFI conection I know the X will do every thing I need
      Joe
      Jul 2012
      Traverse City, MI
      Got mine installed and running finally this weekend. ProTip, if you cant find your OEM injectors in the list in the wizard (and theyre on the HOlley supported injector list) then theyre probably in the other ignition injector list.
      When you go through the wizard, it ask if youre 24x or 58x reluctor, the very next screen is Choose Your Injectors. You'll notice it says 24X tooth ign OEM injector sets at the top of the screen. I clicked around for a bit until I went back and selected 58x and went to the next screen and found my injectors. What I ended up doing was selecting the correct reluctor and picking a random injector. I finished the wizard and didnt start the car. I pulled the SD card out the handheld and went to the laptop and loaded up the file created by the wizard into the Terminator X software and changed to my correct injector type there.
      Project thread - https://www.pro-touring.com/threads/...ouring-Project
      IG - @tc_chevelle
      Just uploaded part 3 video for the Terminator X software.
      In this video I cover some consideration that should be kept in mind when scaling the load and RPM axes for the fuel and spark tables. If you find these videos helpful, please like and subscribe to my YouTube channel.
      Jun 2012
      Golden Valley AZ
      Opening up this old thread with a question. I see the Terminator X Max will do DBW, but will it do dual DBW TB's if I were to run a crossram manifold like the Edelbrock? If not, I guess I would have to step up to the Dominator.
      John Rodko
      69 RS/SS Camaro.
      Heidts Pro G IRS w/ 3:90 gear, Heidts Pro G front
      6.0L LQ4 to be TT
      6 speed or 4L80E, that is the question..hmmm
      Future plans for full TMI interior
      Quote Originally Posted by Rodknock View Post
      If you need dual DBW, you need the Dominator, which is what I have on my Cougar.
      Jun 2012
      Golden Valley AZ
      OK, that's what I figured. Also do you know if cruise control can be operated by the Dominator, or is it something that is usually "stand alone"
      I'm putting a TT LQ4 in my 69 Camaro, and I have a HUGE learning curve to go through with all this electronic stuff..
      Thank you for the help and info. I'll continue to keep reading and hopefully not ask too many stupid questions.
      John Rodko
      69 RS/SS Camaro.
      6.0L LQ4 to be TT
      As far as I know, nobody has a working cruise control on the Dominator or any other Holley system.
      I think Dakota Digital's system can be made to work. I should know in a few weeks. I'm wiring my car now.
      GeoffP
      68 Camaro - LS1/T-56
      Jun 2012
      Golden Valley AZ
      Cool!! Yeah, just curious. At the rate I'm going though, the government might mandate we go to electric cars
      John Rodko
      69 RS/SS Camaro.
      6.0L LQ4 to be TT
      Nov 2016
      Cape May County NJ
      I was looking at the X MAX but it looks like it only has 1 O2 sensor. Is this correct?
      A mans garage is his castle.
      Quote Originally Posted by SS Performance View Post
      That is correct. The X Max adds transmission control and DBW. Even if running a manual transmission, I always recommend that people get the Max for the DBW. Also, the Max has the ability to take a VSS input from a stock T56 speed sensor. Having a speed input opens up useful tuning options.
      Feb 2017
      San Ramon, CA
      Well....I thought my Terminator X Max was pretty good until it stopped working....Apparently there is an issue with the LS1 style wiring harnesses that stops the fuel pump and injectors from working....I haven’t even out 5 miles on the car and my green wire went dead. No blown fuses, relay still clicks, just no power to the wire....Adding 12+to the wire allows the car to fire but it runs like crap....Holley is sending me a new wiring harness and I get the AWESOME experience of trying to install it with the engine already in the car.....I installed the original harness beforehand......If I had to do it all over again, I would use a stock PCM, reworked harness and a shop tune....About the same cost with less BS!
      Quote Originally Posted by Juice.Lee View Post
      Did Holley say exactly what the issue is with the harness?
      Digging up an old threat - reached out to Andrew via email. Hoping to use his services soon!
      GeoffP
      Feb 2024
      Hey guys any update on cruise control? Has anyone had success yet?
