    Page 1 of 3 1 2 3 LastLast
    Results 1 to 20 of 53
      Mar 2013
      Sunny Calif
      inverted driveline angles?
      1968 Camaro Convertible
      Hotchkis UCA - Detroit Speed LCA - Hotchkis 600 LB rate springs front - 178-180 lb leaf spring rear
      Hotchkis tuned fox shocks front and back
      18" wheel, 275 35 18, 25.6" diameter - 3.5 drop in front - 3" drop in rear, 8.5 GM 10 bolt,LS2, 4l65E, zero vibration.
      Front ride height measured from fender lip is 25.25 front and 25.75 rear
      No odd harmonics accelerating or decelerating and none present at cruising or freeway speeds.
      Driveline angles are backwards due to lowering of vehicle?
      Engine,trans is 2.6 down - driveline is 2.9 up - pinion is 1.2 down with the pinion angle above the trans/driveline ride height.
      Should i try and correct to eliminate the 5.5 and the 4.1 working angles?
      if so how best to proceed?
Size:  98.0 KBName:  DRIVELINE.JPG
      Dec 2008
      Detroit
      Probably want to state what vehicle you have to give and idea of how the suspension is setup.
      Big dreams, small pockets....
      Chris--
      '72 Cutlass S LSA/T56 Magnum
      Project Motor City Madness
      Oct 2011
      What is driveline angle? Is that the angle of your driveshaft? If it's a positive number that means your rear end u joint is higher than the transmission, many on here have lowered their cars 3" in the rear, I don't think their rear end is higher than the transmission output shaft. Also you are measuring at ride height? With your cars full weight on the ground? I don't think it makes sense that your driveshaft is pointing up coming out of the transmission.
      Mar 2013
      Sunny Calif
      Driveline angle is positive 2.8 deg and yes pinion is higher than transmission.
      yes ride height on level ground with full tank of fuel minus driver.
      no, eng and trans is 2.6 down when connected to driveline which points up forming a downward V with a working angle of 5.5 deg.
      driveline is 2.9 up in relation to pinion forming an inverted /\ at a 1.2 deg with a working angle of 4.1 with the pinion angle above the trans/driveline ride height.
      Oct 2011
      Can you adjust the transmission up to match the 1.2 degrees up on the rear?
      Mar 2013
      Sunny Calif
      There is some room, i can shim up trans, not sure how much though, will need to raise at least 1.4 deg but not sure how much that is in inches.
      Will give it a shot this weekend.
      Dec 2010
      Fredericksburg, VA.
      Are you currently experiencing any drive line vibration?
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Feb 2016
      Texas
      Your schematic shows the pinion pointing up 1.2 deg, but you say it's down. Are you referring to the working angle between the pinion and the DS being down? If your trans is pointing down and your pinion is pointing down it's definitely wrong. If the pinion centerline is actually pointing up, at least you're getting close to having the centerlines of the trans output shaft and the pinion being parallel. Shim up your pinion to make it parallel to the trans centerline and see where you are at that point.
      Mar 2013
      Sunny Calif
      Okay finally got driveline angles close enough, i think any thoughts on new dims?
      eng trans 2 deg up, driveline 3 deg up, pinion is above trans centerline pointing up 2.4 degrees.
      trans to driveline working angle 1 - driveline to rear pinion working angle 3.0 degrees - final driveline operating angle is 2.9 deg with zero harmonics at all velocities.
      Oct 2011
      I think you need to lower that pinion angle to something down. If your tranny is pointing up because your rear is higher than your tranny centerline then your pinion angle should be down not up. It’s great you don’t have any vibrations but I think everything will wear out very quickly. Your tranny angle basically has to be opposite your pinion angle so that they cancel each other out. Idk that’s my .2 cents
      Mar 2013
      Sunny Calif
      alright, raised trans and lowered pinion.
      engine/trans is 1.5 down - driveline is 1.9 up and driveline is 0 with pinion above trans center line.
      this calcs to front working angle of 3.5 and rear working angle of 2.0 and a final driveline operating angle of 1.5
      this look acceptable to anyone else, keep in mind car is lowered and pinion center line is ABOVE transmission center line.
      Apr 2018
      Oakland
      Hey, I’m having the same problem. My trans is -3.6, drive shaft is +1.8, and my pinion, I set it to -3.4.
      my angle 1 & 2 is out of spec but my working pinion angle is good according to tremec app.
      mid I could somehow get my driveshaft into the negative, I’ll have all free light on the angles.
      what did you do?
      Sep 2016
      Bakersfield, CA
      The Magnum T56 in my 69 Firebird points down and my local driveline shop re-welded my leaf perches so the pinion is up, that way they are both opposite the same amount and cancel each other out. I think my trans is like 2.8 degrees down and my rear is 2.8 degrees up.
      I've been chasing what seems like a shifter rattle in the higher RPMs but I've also read recently that the pinion should ALWAYS be down, meaning just having them opposite is not good enough. I bought my kit from SST being told I didn't need to modify my trans tunnel and they said nothing about the rear pinion needing to be down. I'm going to be a little pissed if that turns out to be the case and I have to modify my trans tunnel.
      Any thoughts?
      http://www.TheFOAT.com/92GTA
      1969 Pontiac Firebird
      w/BP 461ci stroker kit, 670 heads & XE274H cam. Primer black with black interior.
      Oct 2015
      I’m running into the same uphill driveshaft angle on my 67 Chevelle. When I get the new rear end setup in I think I’m going with a CV driveshaft from the driveshaft shop. I have no room to raise the trans.
      My half a$$ed build thread.https://www.pro-touring.com/threads/...elle-6-0-4L60E
      Tighten it till it strips & back it off a quarter turn.
      Quote Originally Posted by anguilla1980 View Post
      Any thoughts?
      If your situation is anything like this:
      Then you have to either raise the back of the transmission or use a CV joint driveshaft from The DriveShaft Shop.
      Sep 2016
      Bakersfield, CA
      It is like that. I already have my new DynoTech DS installed, it would suck to get another.
      So it's an absolute must that the tail shaft be UP and the pinion be DOWN no matter what?
      Oct 2015
      I know your driveshaft is the opposite direction but the trans and pinion are to be at the same angle parallel. Depending on your rear suspension the pinion should be down up to 4 degrees or so.
      Mar 2020
      All of this conversation appears more complicated than it needs to be.
      Here are a couple basic items to take into consideration...
      1. Generally the engine/trans is angled downward towards the rear (typically 3-5 degrees with respect to the frame) because they are usually mounted higher than the differential.
      2. On a leaf spring vehicle, you typically want the pinion lowered an additional 1-2 deg to compensate for torque reaction. Some go as high a 5 on a drag race only application. 3 & 4 link or torque arm style suspensions do not typically have as much rotational issues, but care must be taken to see what happens through the full range of suspension travel.
      3. Once you lower the car to where the driveshaft becomes close to straight (under a 2 deg angle), it Is best to start to level the engine & rear to keep some angle in the u-joints. It is preferable to always keep at least 1 degree minimum in each joint. The Ideal situation is to have equal angles on each U-joint, but this contradicts item #2.... so some compromise must be made.
      On a very low vehicle (where engine/trans is lower than the rear), I typically start with trying to make the trans & rear parallel, then check the u-joint angle to make sure there is about 2 degrees minimum on each. If not, raise/lower the trans accordingly to get it dialed in. I then tweak the pinion down slightly to compensate for torque reaction.
      Generally on lowered vehicles, there is limited suspension travel & stiff springs, all of which help to keep the drive line in alignment & require less pinion offset.
      Sep 2016
      Bakersfield, CA
      Quote Originally Posted by Alwhite00 View Post
      Thank you. That diagram showing how they need to be parrallel helps a lot.
      Apr 2014
      JAPAN
      Country Flag: Japan
      Quote Originally Posted by MAGONSTERZ68 View Post
      My Camaro has the same problem.
      How did you fix it?
      Speed tech torque arm suspensions
      1970 Camaro Help me. A difficult problem in Japan.
