    Results 1 to 11 of 11
      Nov 2015
      Trunk-mounted battery grounding.
      My first post. A lot of great technical info on this site that is not found anywhere else.
      A few questions about grounding for trunk-mounted batteries to determine what solutions others may have employed. I used the battery relocation kit from M.A.D. Electrical. Per the instructions, the battery is grounded to the body in the rear. My questions concern the ground at the front of the car:
      1. Can I ground from an aluminum head to the body? Or does it have to be from the engine block to the body?
      2. If it should be to the engine block, can it be from the body to somewhere on the transmission? I could attach to a bellhousing bolt but they are not easy to access with the engine in the car. And there are no other unused threaded holes on the block that would be a spot for grounding.
      Chad
