Thread: Weld through primer
08-22-2016 #1
Weld through primer
I removed the spare tire well on my '55 Chevy and am about to plug weld in a flat panel. I want to protect between the flange and panel from rust. I started to spray it with a galvanized weld through primer and started thinking if that is the right move or not. Is the galvanized weld through primer best for corrosion resistance? When plug welding, can you actually weld directly to the primer or do I need to hit bare metal? Using a mig if that makes any difference.
