      Jul 2011
      Pinion Angle Finally Solved
      I know there are a ton of threads on this and I have read through a ton of them but I finally made sense of a few and figured out my harmonic vibration issue above 70/75! Now the way I did mine is off the wall and never read it anywhere so I wanted to share it. Maybe I got lucky and this isnt the way to do it but whatever.
      For a long time I kept moving my pinion and trans around trying to get these damn angles opposite, and had a few issues along the way. One of my issues kinda was I was not on level ground, its pretty level but still had a little bit of a slope. I know this doesnt really matter but still cause me confusion. I wasnt doing the math correctly i guess? I think some times I was reading a positive angle as a negative or vice versa which causes all kinds of headaches. Any way lets get to it.
      First ill give you my specs, car is running a triangulated rear 4 link with standard poly rubber bushings, t56 magnum with 0.50 6th, 3" steel ds, energy suspension trans mount, motor is about 300-350hp 360 Mopar, 3:91 gears.
      Ok so I leveled out my drive shaft and measured the angles! Yes I know some people might think im crazy but what I have determined was that the angles of the trans and rear end are relative to the ds. so instead of trying to figure out all this math, why not make the ds at 0* and then what ever your trans is sitting at and your rear end is sitting at is your actual angle! This just hit me the other day like a ton of bricks. I searched and searched for someone who did this but never could find any backing so I said screw it and tried it and boom 90 smooth as butter!! What I found out when I made my ds level is my trans was pointed down towards the ground at .7* but my rear end was also pointed down towards the ground as .5*, which I knew was not right. It was mind boggling at first because what I had the car sitting pretty level in my garage, my trans was like 1.9* down and my rear end was pointed up .5* and the ds was going down hill roughly 1.3* from front to rear. Everywhere I looked, this was supposed to be fine, i was within 3*, my angles were opposite and wanted to give some room for pinion to climb. Well I guess i dont have enough power or something but pinion wasnt climbing. So I put the front tires on blocks, jacked up the rear by the axle so suspension was loaded, and kept going untill my ds read 0*. I adjusted my rear end untill it was pointed up .5*, so now the back of the trans is pointed downhill at the floor .7* and rear end is pointed uphill towards the sky at .5* and the ds is sitting at 0*. I dropped the car back down on the ground, made sure my ds was still running down hill from front to rear and it was, took it for a drive and wow its gone!
      To me leveling out the ds took the math out of it and your left with your true angles of the trans and rearend. I kept reading how the angles of the rear and trans are Please feel free to correct me or let me know why this shouldnt work or what issues I may run into doing it this way, i wont get but hurt I just hope this might help someone out there fix there vibration. I have been fighting this for about 3 years now.
      Aug 2008
      Iowa
      good work
      Leveling the DS is not needed, but if it helps you wrap your head around what is going on, then so be it.
      Pensacola, FL
      I thought of this but never did it. I had my newly finished 67 perfect right out of the box, but my OCD self wanted the rear wheels perfectly centered in the wheelwell. I have adjustable lower bars, so I centered them (this lowered the pinion). I counted the turns, and turned the upper bars the same # of turns thinking this would raise the pinion the exact same amount, putting the pinion right back in the same place....wrong. horrible vibration. I guess the ratio from lower to upper bars is not 1:1. I have made an adjustment since, & its better but not where it was initially. I'm going to measure tomorrow. I'm wondering if If I affected the driveshaft- by moving the wheels back I pulled it too far out of the trans. Thanks for your point of view.
      Scott
      Quote Originally Posted by Z06vet View Post
      Scott
      Scott,
      Post some pictures of the driveshaft inside the trans at ride height...
      Jul 2011
      Yes I knew leveling is not needed but yes it helped wrap my head around everything. I never really read anywhwere that some did this so I just figure if this helps 1 person out there, then great!
      Anniston, Al
      Quote Originally Posted by Gdub View Post
      Nice work man, I will use this when I get to that point for sure! It's always nice when someone passes along a trick or a little knowledge that will save someone some headache.
      1967 Firebird (current project)
      1967 Firebird (unfinished project SOLD)
