    Results 1 to 12 of 12
      Jan 2011
      Pennsylvania
      Griffin Radiator Questions 1970 GTO
      I just picked up a clearanced Exact Fit Radiator from Summit for my 1970 GTO project. I was wondering if someone could help me with a couple questions about it. First, there is a silver plug on the top corner. Is this a place to tap in a steam line for an ls motor, temp sensor, or what? The second question is about two threaded fittings on the side. They have some kind of nut thing around them. It looks like two additional taps? Is this something Griffin would have done or is this a modification by someone? Any idea what the purpose of them would be? I have attached a couple photos.
      Thanks for any help.
      Melbourne, FL
      Is this for an auto trans setup ??? Looks like the two fittings would be for trans cooling lines. The other for a trans fluid temp sensor. Just a WAG ...
      Jan 2013
      Cypress, California
      Yes, the two on the left with the bronze nuts in your picture are for an automatic transmission cooler. The plug in the bottom left of your picture could be used for the steam line. That is what I would use it for. The photo has the radiator upside down.
      Jan 2011
      Pennsylvania
      Thanks guys. That makes sense. I've never had an automatic car so i was thrown for a loop.
      Nice set-up! Are you doing a LS swap?
      Jan 2011
      Pennsylvania
      Yep. Going LS. I'm building an LSA motor piece by piece with some adjustments. The ZL1 guys are dumping a lot of stock parts these days.
      Quote Originally Posted by orbital1970goat View Post
      Like what? Just curious...
      Jan 2011
      Pennsylvania
      Superchargers, injectors, intercooler pumps, intercooler heat exchangers, 6 piston brakes, etc. Basically anything they are upgrading for more power or pulling off of crashed parts cars. My build thread is here where you can see some of what i've collected.
      https://www.pro-touring.com/threads/...70-Pontiac-GTO
      Aug 2015
      Country Flag: Australia
      The one you believe is the for the steam port is actually a drain plug, the rad is upside down in that pic as the cap/filler is at the bottom.
      Jan 2011
      Pennsylvania
      Yes the radiator is upside down. However, the brass petcock is in the top right corner where it would drain. The fitting to be used for a steam port is silver close to the filler cap.
      Benicia, Ca.
      Griffin is only doing LS swap rads with Inlet/Outlet on the Pass. Side. That is a standard unit that is why there is no steam tube port.
      Matt
      MCB - Matt's Classic Bowties
      5360 Gateway Plaza Dr.
      Benicia, Ca. 94510
      866-628-8746
      TEXT ONLY: 925-989-9091 (Replied 8-4)
      www.mcbparts.com
      Email: [email protected]
      Like us on Facebook for exclusive offers, info and chat: www.facebook.com/mcbparts
      Hours: Monday to Friday 8am - 4pm Pacific
      We ALWAYS enjoy talking to our customers!
      We have a full time staff to answer ALL Questions, Tech Support or Order Status Tracking!
      Make sure it fits - the Griffin I bought off of Summit hit my Steering Pump. I had Griffin make me a Custom Unit
    Tags for this Thread
