    Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
    Results 61 to 80 of 85
    1. #61
      Feb 2016
      Mod motor fits
Size:  234.2 KBName:  IMG_9864.jpg
Size:  273.4 KBIf it fits it ships... gotta do a custom engine compartment bracing to keep the walls from caving in but it's coming together. Right fit on the brake master cylinder and mocking up the cobra Manuel pedal box
    2. #62
      Feb 2016
Size:  244.6 KBName:  IMG_9328.jpg
Size:  128.8 KBAlso desided to go w 2015 mustang track pack brakes front and back. Those are some big ass brakes. Killer looking w 14" rotors.
    3. #63
      Feb 2016
      Few more pics
Size:  290.2 KBName:  IMG_9922.jpg
Size:  216.7 KBEngine compartment bracing and cobra pedals mounted
    4. #64
      Jun 2016
      Evansville IN
      Any more pics of the pedals mounted?
      I plan to run the cobra pedals and hydroboost
    5. #65
      Feb 2016
      I'll try soon. Had to do a lot of Fab work the quadrant needed to be moved to the left side I should have better pics when all the parts come in
    6. #66
      Jun 2016
      Evansville IN
      Looks like the t56 didn't fit in the stock tunnel. Did you have to raise the tunnel?
    7. #67
      Aug 2009
      Brandenburg, KY
      Ford Modular
      Nice job. Looks great! I'm building a 1940 Ford Tudor and will be installing a 1996 4.6l SOC. I installed the 2004 PI heads and intake. This should make the car scoot down the road.
    8. #68
      Feb 2016
      Quote Originally Posted by Wldtang View Post
      Yeah it needed to be raised about 2in in the front section to get the drive shaft angle right
    9. #69
      Feb 2016
      Pedal mounts
Size:  187.7 KBName:  IMG_9927.jpg
    10. #70
      Feb 2016
      Front wheel
Size:  171.7 KBHad to re fan the front A arm cause the aje kit makes it sit to far foward but now it's right in the middle
    11. #71
      Feb 2016
      More progress
Size:  690.3 KBName:  IMG_1650.JPG
Size:  705.0 KBName:  IMG_1616.JPG
Size:  633.1 KBName:  IMG_1573.JPG
Size:  686.7 KBName:  IMG_1492.jpg
Size:  127.2 KBName:  IMG_1445.jpg
    12. #72
      Oct 2016
      Looks like a fun build.
    13. #73
      Jul 2017
      Curious as to what wheels those are the look badass. Good job on the build so far!
    14. #74
      Feb 2016
      Tsw Bathurst. Closest to the Shelby super snake wheels I could find w the right options on back spacing and rim size w out spending 1500 a wheel
    15. #75
      Apr 2015
      Burlington KY
      what did you do to the AJE front arms? Mine actually sit forward on the ps and ok on the ds....may be the fender isnt on right but looks close.
      "Racing is life. Everything else is just, waiting"
    16. #76
      Feb 2016
      Quote Originally Posted by xsboost90 View Post
      Had to cut almost an inch off the side closest to the firewall and reweld it back up. Both mine sat forward to much aje also makes a “fix” for that. They have adjustable arms but there like $400 something
    17. #77
      Feb 2016
      More pics
Size:  217.1 KB Went with 14” Shelby brakes all the way around
    18. #78
      Feb 2016
      Built a box frame for the fuel tank to mount too to stiffen up the rear some more. Got seat pans in and the rest of the floor roll cage built an out rigger from the sub frame to the roll cage for support and 14” Shelby brakes on all four corners. Yes that is way to much brake for the rear but it looks way better and the will use a portioning valve to make them work
    19. #79
      Feb 2016
      Pics
Size:  295.2 KBName:  0F8B011B-284B-49C4-9EB1-C787523FE3FC.jpg
    20. #80
      Chicago
      Just read the entire build.
      First off I love that it’s a coupe and the build is awesome. Looking forward to watching the rest of the build.
      marty-mj
