    Page 3 of 3 FirstFirst 1 2 3
    Results 41 to 46 of 46
    1. #41
      Jan 2016
      hi.im using a mittler bros bead roller.the beads themselves are not that deep.try not to do them to deep,as it keeps the distortion down on the panels
    2. #42
      Jun 2014
      Country Flag: Sweden
      ok thanx
      my bad for explaining bad i meant how far in on the metal you reached,mine isn't that wide in the jaws so to speak
    3. #43
      Jan 2016
      It has a 3 foot throat. What you can do is get as far as you can until the metal hits the frame.then flip over the dies and beed from the other side.
      That doubles the capacity you can do
    4. #44
      Jun 2014
      yeah i done that,but mine is juston foot deep,i need to make a new frame and resuse the axels on it,
      cheers
    5. #45
      Nov 2009
      the dirty mitten
      If you are still having starter issues, I was having the same issues. You just need one from a chrysler 300 or challenger. Should be able to find one locally so you can try it and return it if needed. I had an issue tho with it because I have a Mopar aluminum flywheel that has the ring gear further away I guess than the stock application. I ended up removing the gear from the starter, flipped it around and welded it back on further away, engages nicely now and I didn't have to use that stock heavy flywheel
      Steve
    6. #46
      The Netherlands
      Country Flag: Netherlands
      very nice fabrication work Wayne! can't wait to see more.
      1st 2nd
      Pro-Touring outside the USA !
      Martin's Camaro Page
