    Results 1 to 20 of 20
      May 2012
      Hungary
      Country Flag: Hungary
      Speedtech upper control arm angle seems too much under load?
      Hi All,
      My car ( 72 Nova ) just got the new suspension components and they look a little weird to us.
      It looks like the upper control arms will have pretty high angle under load and even at lowered ride height.
      They are Speedtech control arms with ridetech SA shocks.
      We tried the factory spindles with Kore3 hubs and CPP tall spindles with C5 hubs. However with factory spindles looked "ok" but it wont let us to use 255 wide front tire. It does not turn without getting contact to other parts.
      The CPP tall spindle with the corvette hubs seems good ( the tire turns perfectly ) but it is taller of course ( I think a little more than 1" ) and it put the upper arm in a high angle even on lowered ride height. I assume it might be dangerous at a big bump that will push the arms up to an even higher angle.
      How much angle the moog ball joints and the tubular arms can handle?
      I am planning to buy the Speedtech's AFX spindles next year but I think it is even taller than this so it might be worse actually. Well, I really don't know what would be the "normal" look
      As you can see the car has to be lowered at least 1,5"-2" to have the right stance so the control arm angle will be higher. The tire diameter is 26"
