    Results 1 to 17 of 17
      Oklahoma
      LSx Swap pitfalls
      What are some of the common pitfalls people fall into when swapping over to a LSx powertrain? I have a 68 Camaro with aftermarket sub frame. I already have an LT1 in the car. The LT1 has developed a rod bearing knock so I'm looking at all my options on moving forward.
      1968 Camaro, 1995 LT1/4L60E, 3.50 Ford Nine Inch, 85MM Delphi MAF Sensor, Dynatech 1 3/4" Headers, MagnaFlow 2 1/2" exhaust with X-pipe crossover, Total Cost Involved Sub-frame, 4 Link and Frame connectors, Centerline Boulevard 17's, Nitto Invo's on the pavement
      Feb 2012
      There are ALOT of problems you will encounter if you swap to an LS---
      --Not enough rubber, It seems those that swap need more tire width. Small tires just don't hold up.
      --Wiping the big smile off your face
      --Less time, People keep stopping you and asking "What's that got in there"? It takes a lot of time away from driving
      I would suggest a nice 289 single-barrel ---Early 70's pickup should do for a donor.
      This is the build thread for my car
      https://www.pro-touring.com/threads/...-Beak-Job-quot
      Jan 2013
      Cypress, California
      There are plenty of people who have done this swap. I would suggest just doing a search and look at what others have done. Then pick one that suits what you are doing and follow along.
      May 2010
      kitchener,Ontario,Canada
      Are Being awesome and easily diagnosing future problems,easier starts in cold weather, better fuel economy and, less weight pitfalls ?
      Ryan Austin
      On Instagram ryanaustinss70
      Mar 2013
      Most of the annoyances that were typically encountered with your swap application years ago can be avoided by taking the time to create a list a features, build characteristics and major parts that you'll want the finished project to possess. If you describe the ride stance, transmission, A/C system, suspension and steering system you want to use as part of your complete build then the examples of the most appropriate engine mounts, headers, transmission crossmember and exhaust system will more quickly be identifiable to you.
      I would pick a vendor that has a complete system that includes mounts, headers, and transmission crossmember. Holley offers nice components, but if you already have an aftermarket front subframe, you probably have to figure something else out.
      If your car is lowered (I assume it is), you will need to pay close attention to driveline angles. The engine needs to sit as low as possible and the back of the transmission will need to be as high as possible.
      Feb 2013
      I used all Holley parts for my swap
      Mounts,headers, trans mount, the engine install was prob one of the easiest parts of the project
      Oklahoma
      Thanks for the replies.
      Here is the Car:
      current motor:
      Atlanta GA
      The worst thing is that my car is daily driven.. heavy traffic.. long hauls.. short hauls.. to the skatepark.. to the bank.. to get ice coffee... all driven to very fast(which is bad) and its SUPER annoying that comfort is there.. I feel like a wuss.. I dont reek of gas and I get too many miles per gallon for a musclecar..
      so yea.. kindof sucks.. lol.
      That's why I look up to you, as tough as you have it you keep plugging away!!!
      Jacksonville, FL
      I swapped from an LT1 to an LS3, no regrets at all. Like Andrew says, I would call you subframe manufacturer and see what they recommend for the swap parts. You won't be disappointed!
      Chris
      1968 Chevy Camaro SS
      LS3/4L70e, DSE suspension
      Jun 2009
      Piqua, Oh
      Love the Wheels...
      I have long tube headers, that seemed to hang down too much. They would drag badly at the stance you have in that picture.
      I ended up raising the back of the transmission 1.5" to help with ground clearance and drive line angle.
      Mike South
      1968 Camaro SS/RS LS1/T56
      Ride Tech Tru Turn, Ride Tech T/Q Coil-overs
      Ride Tech 4-link
      Oklahoma
      I have since raised the car about 1inch. I haven't had any issues dragging. Only thing I have is a bit of rear tire rub going into or coming off of some bridges. I missed the back spacing when ordering the centerlines by about 1/8th inch I think.
      Jan 2014
      Seattle WA
      Hard to argue with any of the above. I guess the only thing would be lack of understanding going in. Approximate cost, time, your skill level. Been done a few times and plenty of good options to choose from. Good luck with your build!
      1967 El Camino 408ci LSx....and the build begins!
      1967 Turbocharged 408ci LSx Chevelle - 1012 rwhp, 959 rwtq 67 Chevelle
      2009 Supercharged Silverado - On the Dyno
      Aug 2013
      Alabama
      Headers was my biggest problem so get a nice set from the get go. As others said, tire life will be reduced, my mpg is way higher than my 6 cylinder import, and it revs a lot higher than the small block so make sure your tach can go that high
      Sep 2015
      I ditched a tired R/T motor for an LS a couple of years ago, and never looked back.
      3 things I tell people who are first-time swap.
      1) Buy a complete drivetrain out of something, with all of the supporting stuff
      2) Find a good tuner who will work with a swap, and talk to them before buying a drivetrain
      3) Set aside space and money for it. It will take longer, and cost more than you think. Nothing sucks worse than trying to work on it while it is in the way of everything else. It gets old, real quick.
      Oklahoma
      THanks for the info. Looks like I'm heading the LS route.
