    Results 1 to 16 of 16
      Mar 2003
      Boringville
      weird, maybe you are getting trash in the floats, and gas is pouring out of carb, woudln't make it backfire though, could be the mechanical advance in dist? maybe have your ign. system checked out my MSD, check grounds?? should be ground straps from engine to frame, and body to frame. Next time it happens, check for fuel delivery, maybe the pump is acting up. Unfortunately it could be many things, sounds like you need to look at it when it actually is happening.
      EDIT, read again, sounds like an ignition problem, i would check all the connections on your MSD system.
