    Results 1 to 16 of 16
      Dec 2000
      NE Florida
      Have you checked for vacuum leaks? How much did you torque down the blower? IIRC, they are only supposed to have like 12-15lbs on the blower bolts. More than that, and you'll warp the case (creating a vac/boost leak). What I'm thinking is that when your engine is cold, you have a gap or leak somewhere, then when it warms up- it closes up the gap.
      As far as plugs- you say it runs fine after this horrible warmup? Define fine...
      Do you have any type of boost / timing device besides the 6AL? ex: a Boost Timing Master that will yank out some timing under boost and during start? I'm assuming you're using a 'double-pumper' style carb, and not a vac secondary?
      Quote Originally Posted by OHCbird
      I was very careful when I torqued my blower on, 12 ft lbs. I have no other timing device. I am running a Demon with vac secondaries. Why?
      When I say it runs fine after an occasional bad warm up I mean fine. Totally normal, you can romp on it, idle, cruise etc with nothing abnormal happining. Runs like a champ.
