    Page 2 of 2 FirstFirst 1 2
    Results 21 to 37 of 37
    1. #21
      St George Utah
      Quote Originally Posted by Nicks67GTO View Post
      Will the updated AFX spindles do anything cool for the A-body crowd?
      it will NOT fit an A BODY it uses the wrong ball joints. I have not plugged the numbers into the suspension program to even see if it is close. once I get through all this I will look at it but don't hold your breath, the CURRENT AFX spindle works wonders on that platform.
      Blake Foster
      www.speedtechperformance.com
      435-628-4300
      St. George Utah.
      it's always sunny here.
    2. #22
      Mar 2012
      Orange County, California
      Good stuff Blake. Look forward to seeing more.
    3. #23
      Aug 2011
      Connecticut
      Quote Originally Posted by killer69 View Post
      No decision on that, yet
      Definite dream come true if that happens. Then I can afford the frame I need
      1967 Firebird "Poor-Boy Build"
      New updated thread
      https://www.pro-touring.com/threads/...bird-(Updates)
      Follow me on Instagram @NaturalLivingMan
    4. #24
      Jul 2007
      sweden
      pics ... Plbbeeaaase ;-)
      Price wise?
      Happy news came now as I was thinking of a subframe.
      But this will not be upgradeble as the old one right?
      camaro69-l92 with 6l80e considering mast ho cam 530hp - speedtech(LCA)-ats Street-Comp AFX-unisteer r&p - VariShock coilover QuickSet2-Hydratech Brake Booster - 5gen rear suspension
      movit brakes 380mm 6piston front-465mm 4piston rear - 275/30-19 front-325/25-20 rear 19x9f 20x12r cray scorpions
    5. #25
      Nov 2012
      Sacramento, CA
      Quote Originally Posted by holschen View Post
      Price wise?
      Sorry, but there are no photos available yet of the front subframes. This was just an announcement of what's coming soon. We're currently taking pre-orders & creating a build list.
      If anyone has more or different questions about the suspension in the full chassis or front subframes ... I'm happy to help.
    6. #26
      Nov 2012
      Sacramento, CA
      Price wise?
      New Speedtech Front Subframe & Suspension Package
      New Cutting Edge Design Includes:
      • Strong Box type laser cut and jig welded construction - reduced weight over factory subframe.
      • Special subframe width & shape allowing 315 front tires.
      • Factory alignment holes offer ease of aligning frame to body and bumpers.
      • Mounting hardware, instructions, and custom alignment specs.
      • Ron Sutton Race Technology geometry built-in.
      • Upper control arms feature additional caster adjustability.
      • Speedtech high clearance upper & lower tubular control arms
      • Control arms powder coated gloss black and fully assembled with Delrin bushings.
      • 3-piece Speedway Engineering sway bar – Wide choice of rates.
      • Unisteer power rack & pinion steering.
      • Next-Gen ATS 7075 Forged Aluminum Spindles.
      • ATS high-Ackerman steering arms for ATS spindles.
      • C7 heavy duty bearings & hubs.
      • Increased header and exhaust clearance.
      • Motor stands accept small block engines with OEM style mounts.
      • Accepts LSX engines with Speedtech fabricated oil pan and motor mounts.
      • Adjustable engine frame stands allows 3/4" fore & aft range.
      • Fully adjustable rear cross member fits all GM transmissions as well as T-56 and TKO.
      • Built-in tow/tie down hooks eliminate strapping around painted frames.
      • Comes bare. Powder coat options available.
      From Speedtech Performance, the base package includes:
      • Viking double adjustable twin tube coil-over shocks, including delrin thrust washers & adjusting wrench.
      • Viking coil-over springs – Wide choice of rates.
      • Base Price for complete subframe & suspension is $6899 + $200 crating fee
      From Ron Sutton Race Technology, the base package includes:
      • ridetech single adjustable mono-tube gas coil-over shocks, including delrin thrust washers & adjusting wrench.
      • Hypercoil coil-over springs – Wide choice of rates.
      • Base Price is $7099 + $200 crating fee
      OPTIONS:
      • Powder Coat Subframe – Flat Black
      • Powder Coat Subframe – Semi-Gloss Black
      • Powder Coat Subframe – Gloss Black
      • Powder Coat Subframe – Gun Metal Grey
      • Powder Coat Subframe – Silver
      • Billet Aluminum Body Mount Set
      • Engine Bay Round Tube Chassis Down Bar Supports
      • Double Joint Steering Shaft Kit
      • GM Steering Column Adapter .
      • LSx Engine Adapter Plates
      • Speedtech 1 3/4" LSx Headers, Mill Finish
      • Speedtech LSx 1 3/4" Headers, Show Polished Finish
      • Speedtech 2" LSx Headers, Mill finish
      • Ron Sutton Tailored Suspension Tech Service #40STP
      • Ron Sutton Tailored Brake Tech Service #29
      ridetech Digressive Triple Adj Shocks w/AutoX-Star Valving
      • Ridetech Digressive Triple Adj Shocks w/AutoX-Star Valving
      • JRI Digressive Triple Adj Shocks w/AutoX-Star Valving
      • JRI Digressive Triple Adj Shocks w/Track-Star Valving
      If you like to spec one out for your car project, contact either:
      Speedtech Performance at:
      Phone:(435) 628-4300
      Shop: 3884 S. River Road, Bldg. A, St. George, Utah 84790
      Email:[email protected]
      Website: SpeedtechPerformance.com
      Ron Sutton Race Technology at:
      Phone: (916) 834-8051
      Email: [email protected]
      Website: RonSuttonRaceTechnology.com
    7. #27
      Jul 2010
      Texas
      New sub-frames sound great! Couple of questions I'm running a LSX motor /T-56 trans in 68 Camaro ...
      What oil pan clears frame/rack pinion?
      Motor mounts/ motor position?
      Headers?
      Will my factor Camaro (4th gen) front drive accessories clear ?
      Thanks for the time
      Ryan
    8. #28
      Jul 2010
      Texas
      Any updates on the sub frame? Pic?
    9. #29
      Nov 2012
      Sacramento, CA
      Quote Originally Posted by greatwhitebuffalo View Post
      Headers?
      Thanks for the time
      Ryan
      Ryan, Blake Foster of Speedtech will need to answer these questions as he is doing all the mock up in the car. I just designed the suspension & steering geometry. Give Blake a call at (435) 628-4300.
      The very first chassis being built with my new suspension & steering geometry is the Speedtech C10 Truck Chassis. They are just about finished with it & will post up photos in the next week or so. The new 1st-Gen Subframe will be "similar" but not identical. The 1st-Gen Subframe is not in production yet. The design work is completed & it is in the prototype & test fit stage. I think Speedtech will start production of the 1st-Gen Subframe & suspension packages we have pre-sold in a few weeks. We can't nail it down any closer than that.
    10. #30
      Nov 2011
      Livermore, CA
      w0w I missed this thread, glad it got bubbled back up. Having Ron as an advisor /contributor to this is huge.
      Since the A body (66 Chevelle) is not listed, where should I send the car to get proto typed? )
      subscribed
      Livermore, CA
      American:
      1966 Chevelle SS "Tribute" Retro / Pro-Tour
      For Sale
    11. #31
      St George Utah
      Headers?
      Thanks for the time
      Ryan
      its is a little early to answer all of these 100%
      We KNOW the ATS and Autokraft will fit. the GM muscle car pan MAY the design of this suspension is NO COMPROMISE so something MUST give. We are Pretty confidant that a Big Block WILL NOT FIT, height wise. for instance, but really this is a road race auto X suspension and you will be using a LS or SBC.
      Frame stands will come with the sub frame (included in the price) LS or SB the ATS adaptors will still need to be used.
      the Engine position.................. it will sit where it FITS.
      we will have headers that FIT, I can guarantee NO off the shelf header will fit. it is SUPER tight.
      The eonly issue will be the AC compressor, as per usual, we have tried the CTSV and Corvette and the pump physically will fit it is the location, the fittings are the issue they need to come out the top of the pump we found a TrailBlazer pump but the distance out for the belt is wrong. BEST bet is an aftermarket drive or No air.
      Blake Foster
      435-628-4300
      St. George Utah.
    12. #32
      St George Utah
      Quote Originally Posted by cactuss4 View Post
      subscribed
      we will have an Abody full frame mid summer. feel free to send it so we can install it for you.
      Blake Foster
      435-628-4300
      St. George Utah.
    13. #33
      Aug 2011
      Connecticut
      I'm excited to see the new first gen frame completed!
      New updated thread
    14. #34
      St George Utah
      Quote Originally Posted by Buryingthesun View Post
      So are we.
      I have the first prototype bolted in a body. working on fitment and that stuff.
      give us a couple weeks.
      Blake Foster
      435-628-4300
      St. George Utah.
    15. #35
      St George Utah
      pics
      This is the front suspension on the C10. the front cross member will be just about identical. the control arms will change in width to narrow the WMS to the required Camaro width of 60" (plus brake hats) we did this because it makes the suspension work a bit better. So at least you can see roughly what it will look like.
      The Camaro will probably use a Sweet MFG rack (waiting for a sample to test fit) which will be WAY better than most others available. This will handle 315 front tires in any application and last.
      The splined sway bar will be available in multiple rates from 570lb for the street to 1250lb for a big road course.
      obviously the sway bar is not installed on this frame yet. Monday
      Name:  C10 Front 3.jpg
      Blake Foster
      435-628-4300
      St. George Utah.
    16. #36
      Nov 2011
      Livermore, CA
      Ron Sutton I'm willing to sign the adoption papers if you will have me? I come with a bit of baggage, a wife a kid and a Chevelle! Can't wait for pictures and pricing, just started looking at the 2-3 options currently available for the Chevelle.
      Tory
      Livermore, CA
      American:
      For Sale
    17. #37
      Nov 2012
      Sacramento, CA
      Tory
      Tory, I'm all in on the kid & Chevelle ... because I love kids or Chevelles. But, we'll have to negotiate a bit on the wife. I love mine, but one is enough
      A lot of people are asking about the new first gen & second gen subframes that are coming ... but the new full chassis is going to be bad azz in the A-bodies, trucks & 567 Chevies. Can't wait.
      FYI: I can't take credit for the style & cool looks of the frame. I didn't design the frame, just the suspension & steering geometry.
