    Results 1 to 10 of 10
      Nov 2011
      College Station, TX
      Ridetech Coilover Bracket
      How much clearance is needed for a ridetech Coilover bearing eye in the bracket? Spec's on their website say it's a 5/8x1in bearing but I assume that's ID and width. How big is the OD on the entire bearing assembly?
      Thanks,
      Central TEXAS Sleeper
      Experimental Physicist
      '64 Riviera T-type: 4.1L Buick Turbo6, 4L80E, L67 OBDII SEFI swap
      ROA# 9790
      Aug 2011
      Connecticut
      I didn't know ridetech made one, I have the Speedtech "chicane" mounts that weld on the factory frame.
      1967 Firebird "Poor-Boy Build"
      New updated thread
      https://www.pro-touring.com/threads/...bird-(Updates)
      Follow me on Instagram @NaturalLivingMan
      Nov 2011
      College Station, TX
      Definitely going to be a custom job, putting coil overs in the original spring locations in the rear is the plan on my Riviera and would need to make adapters brackets from the single stud mounts (really spring locating clamp mounts) to the bearing eye style of the shocks. Knowing that added height top and bottom factors into what length will work.
      ROA# 9790
      Feb 2013
      Hey,
      Here are a couple of images that show the dimensions of the shock.
      Here is just the housing:
      With the spacers added in:
      If you need anything else, feel free to let me know!
      Ridetech Suspsension
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
      Nov 2011
      College Station, TX
      Quote Originally Posted by Josh@ridetech View Post
      Hey,
      Thanks Josh,
      The dimension I'm looking for is the height from centerline to the top of the housing so that I can account for this length in picking a proper fitting shock with a mount that will let it rotate cleanly.
      Thanks,
      ROA# 9790
      Aug 2011
      Connecticut
      Quote Originally Posted by CTX-SLPR View Post
      Sorry I misunderstood your original question! It looks like you have the info you need!
      New updated thread
      Des Moines, IA
      The dimension you are looking for is just under 0.70", however there is a "flat spot" machined into the upper ring mount (which can be seen in the images above), so we typically use a mount that is 1.185" to ensure plenty of clearance.
      You can go lower than this, but make sure nothing hits when the shock moves (like the adjuster knob).
      Feb 2013
      Quote Originally Posted by marolf101x View Post
      I misunderstood, I'm sorry!
      There's the info you need, thanks Britt!
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
      Nov 2011
      College Station, TX
      Thanks! I should be able to sneak a minimal clearance bracket (0.75) since per my calculations the shock won't rock more than 2º from vertical during the full travel of the suspension. If I understand the diagram correctly, the coilovers do have an extension limiter built in correct?
      ROA# 9790
      Indiana
      Yes, the coilovers have an internal bump stop to protect the shock at full extension.
      Herb
      1966 Chevelle 509/T56Magnum
      1963 C10 454/4L80
      PHR CHP CHP youtube
