    Results 1 to 12 of 12
      Nov 2010
      Swapping from DBW to Cable
      I'm buying and LS3 that's coming with the ECU and all accessories ect... I was wondering if the computer can be flashed to be run w/o the DBW and use a cable throttle body.
      Dec 2008
      Detroit
      Quote Originally Posted by firebirdzig View Post
      LS3 is 58x reluctor crankshaft motor. You would need to convert it to 24x to run DBC and run LS1 style PCM. Lingenfelter makes a converter box for such a conversion.
      http://www.lingenfelter.com/mm5/merc...1#.VH_LmjHF-So
      Big dreams, small pockets....
      Chris--
      '72 Cutlass S LSA/T56 Magnum
      Project Motor City Madness
      As was said, it isn't easy, and more importantly, why would you want to? The DBW set-up works awesome.
      Nov 2010
      Thanks for the info. Will a stand alone harness and ECU from an LS2 be plug and play with an LS3?
      Dec 2010
      St Louis
      Around 05-06 I think there were 24 and 58x reluctor LS2s in Vettes/GTOs. So maybe.
      If your goal is to find a 58x ecu with IAC driver to use cable TB, that will be a very rare animal.
      Quote Originally Posted by garys 68 View Post
      It's as rare as a unicorn.
      Dec 2008
      Detroit
      ^^^^ This.... Are you just assuming better throttle response with DBC? If you have the harness and PCM, you're 80% there. Just get the pedal, have your harness rewired and PCM programmed.
      Chris--
      Dec 2010
      St Louis
      I was thinking Jackalope....
      Feb 2013
      Ft Worth, TX
      I'm happy with the drive by wire in my Sierra. I actually have a DBW setup to swap into the Chevelle. DBW gives a cleaner engine bay, less holes in the firewall, and allows you to run cruise control very easily. It's a win win win!
      1970 Chevelle: 6.0 L96, T56, Strange 9 Inch, Ridetech Coilovers, Wilwood brakes
      1978 Firebird: 6.0 LQ4, T56
      2007 Sierra 2500HD LBZ
      Jacksonville, FL
      David, are you running cruise on your current setup?
      Chris
      1968 Chevy Camaro SS
      LS3/4L70e, DSE suspension
      Feb 2013
      Ft Worth, TX
      Not with the cable setup. I'll add a cruise control switch when I install the DBW computer/throttle body.
      Nov 2010
      Thanks for the help guys!
