    Page 3 of 18 FirstFirst 1 2 3 4 5 6 7 8 13 ... LastLast
    Results 41 to 60 of 348
    1. #41
      Oct 2014
      Front end bracing on passenger side:
      Name:  2014-11-29 15.22.25.jpg
      MII suspension in. I added a bunch of gussets to it.
      Name:  2014-11-29 15.22.16.jpg
      I'm going to get some square box tubing to gusset the torque box/pillar/cowl/rocker together with an x-brace. That should give a good load path into everything. That's my theory anywho.
      The tabs will connect heim joint ended rods. They angle is pretty shallow and there isn't going to be much load path, but the main goal is to have a spot to brace the master cylinders (brake/clutch) to, to help mitigate flexy-firewall syndrome.
      1988 Mazda RX7 - Forged LS/T56, 76mm turbo, ProEFI, Ford 8.8 - Sold
      1965 Mustang Coupe - TT Coyote, TR6060, Haltech, big brakes, updated suspension.
      2007 Aston Martin V8 Vantage - Full bolt-ons
      2016 BMW 428iX GranSport - Stock...ish.
    2. #42
      Oct 2014
      Little bit more progress on the front end. Built some internal aprons to cover up the fender wells. The bottom area of these may get a little trim/tweak once the arms get in and I can check clearances. I also want to add a brace on the rear of the MII upper arm mount that will have a bolt that can be used to set pressure against the upper arm pivot to prevent "walk" under load. I'll build a mockup of it once the arms are installed so that I can see if it will work like I want it to.
      Name:  2014-12-01 07.24.06.jpg
      And restoration of the hubs. Here is a shot of before/after..
      Name:  2014-12-03 17.30.27.jpg
      And both completed...
      Name:  2014-12-03 17.41.23.jpg
      I'm not sure why the studs look goofy in the pictures, it's just the camera, they are nice and straight. Big fan of my 20 ton press for... persuading... 50 year old parts to play nice. ;)
      Not much progress beyond this right now. Finishing up a mil-spec harness for a guy with a 1994 RX7 right now, then I have a conversion harness for an LS1 in a Crown Vic, THEN I should be able to get back to the Mustang. That reminds me, after body work is chassis electrical. :D
    3. #43
      Aug 2013
      looks good so far with the progress I like it I love when people build the coupes I have one myself
    4. #44
      Nice progress Blake. Sent you a PM.
    5. #45
      Feb 2012
      compton IL
      like your project. i am doing a 65 fastback, take a look at my thread i have done a ton of chassy strengthening that is not very invasive, everything is subtle & effective
      1965 mustang fastback. a pro-touring concoction of oem, race & custom fab...build thread here https://www.pro-touring.com/threads/...Racesteed-quot
      1975 harley ironhead custom long chopper. home built dream machine. fast, loud & beautiful
    6. #46
      Oct 2014
      Been super busy at work and out and about (PRI in Indy and elsewhere) so I haven't had a lot of time to work on the car.
      I did get the TCI torque arm rear suspension kit ordered up, looking forward to getting that setup!
    7. #47
      Oct 2014
      PROGRESS !!! !!!
      Body work on the driver's side inner fender panels is done:
      Name:  2014-12-27 00.01.47.jpg
      Name:  2014-12-27 22.53.22.jpg
      And got a start on filling/cleaning up the firewall:
      Name:  2014-12-27 22.49.08.jpg
      Took a break from body work (sort of) to play with fender alignment at the door. These fenders/doors fit like total garbage. No clue what brand they are (PO bought them) but wow, they suck. Anywho, here's about 5 hours of work tightening this tiny little area up:
      Name:  2014-12-28 20.40.03.jpg
      Subframe connectors are in, as well as x-brace:
      Name:  2015-01-03 14.10.12 HDR.jpg
      Name:  2015-01-03 19.20.16.jpg
      Outrigger/jacking plates are built...
      Name:  2015-01-03 15.02.36.jpg
      So what is the little cylinder you ask? That will get a delrin insert (who wants to machine some delrin for me?) to function as a jack point without tearing up my undercoating.
      My welding is improving steadily:
      Name:  2015-01-03 15.06.01.jpg
      Front installed:
      Name:  2015-01-03 19.19.37.jpg
      Rear installed:
      Name:  2015-01-03 19.19.54.jpg
      Up top:
      Name:  2015-01-03 19.20.47.jpg
      Name:  2015-01-03 19.20.55.jpg
      Those are welded to the subframe/connectors and the rockers, as well as the floor. Unlike the RX7, I decided to use "through floor" style as my research says it helps to increase stiffness, which on this thing, well, every bit helps.
      Rear panhard mount, coilover mounts and swaybar mounts:
      Name:  2015-01-03 14.10.34 HDR.jpg
      Rear end with brackets and cleanup. This was 2.5 hours of misery grinding all of the last 50 years of crap off of it. Ugh, not fun. Not bad for a 50 year old axle:
      Name:  2015-01-03 19.19.20.jpg
      And with the torque arm mocked up:
      Name:  2015-01-03 19.45.06.jpg
      I need to cut the ends off to center the pinion up properly. I ordered a set of big bearing ends and will have a friend of a friend with a jig weld them on straight.
    8. #48
      Good progress Blake!
    9. #49
      Mar 2010
      Jacksonville FL.
      You've been busy... looks great!
      '66 Mustang Fasback build in progress
      '01 F250 Platinum Edition - 1 of 2482
      '12 Mustang Boss 302 #806
    10. #50
      Oct 2014
      Thanks guys!
      I just ordered up some durablock sanding boards as I only have some small hand sized sanding pads and those no-workie on the big panels/curves, so I'm hoping the big blocks help get everything nice and straight. I'm no expert body man, but I figure it can end up better than average with enough sweat equity.
      I'm really looking forward to setting it on the ground at ride height right now. Can't wait to see how it'll look!
    11. #51
      Dec 2010
      Apex, NC
      I like seeing other people making progress. Inspiring . Looks great!
    12. #52
      Oct 2014
      Okay, been SLAMMED at work, traveling all over, plus my son's birthday and some mil-spec harness work for some other people, but, I present to you... progress!
      Since I improved load path into the cowl area, I though it prudent to improve load path from the cowl area into the hinge pillar and rocker:
      Name:  2015-01-11 16.28.40.jpg
      Axle housing done. My buddy welded it for me with a jig he has setup. TIG'd it. Makes my welds on the brackets look pretty ****ty, haha! He does great work and charges me much less than he should because he's a cool guy.
      Name:  2015-03-05 20.41.55.jpg
      Name:  2015-03-05 20.42.02.jpg
      The fender gaps. Oh lord the fender gaps. Good news: I'm getting better at this stuff. Bad news: There is a lot to do and "better" does not equal good. By the time I get all the way around the car I ought to be a pro though. Here is the method I used to tighten up the 1/4" gap to my "just under an 1/8" gap" that I'm trying for everywhere:
      Step 1: Weld some 1/8" mild steel TIG rod into the area you need. Just tack it and work it with a body hammer (work it baby!):
      Name:  2015-03-07 11.20.27.jpg
      Step 2: Weld it, more:
      Name:  2015-03-07 11.23.56.jpg
      Step 3: Grind it till it looks sorta right:
      Name:  2015-03-07 11.26.46.jpg
      Step 4: Mock the two panels together and, using a cut-off wheel in a grinder, work the gap until it is much closer. I don't have a picture of this since I can't grind and take pictures at the same time without dismembering myself.
      Step 5: Skim coat with mud. I skim over the gap then use a razor blade to slice out the mud in the gap once it starts to go off, but before it fully hardens. This looks sorta thick but it's not:
      Name:  2015-03-07 11.58.08.jpg
      Step 6: Remove the fender, backfill with a little more mud and dial it in, then prime it to seal:
      Name:  2015-03-08 19.00.51.jpg
      Step 7-25: Repeat steps 5-6 until you're tired/angry/swearing. I don't drink, but alcohol may help soothe these steps, though excessive application may cause further repeating of steps.
      Step 26: Voila!
      Name:  2015-03-08 22.22.31.jpg
      While I was at it, I decided I didn't like the flexy fender behind the front wheel, so I added a small brace:
      Name:  2015-03-07 11.57.44.jpg
      Still need to fix the door/fender gap the rest of the way down, but that's easier than the whole door/cowl/fender/pillar combo area at least. Then I need to fix the door/rocker gap, fix the door cowl line (OMG that's going to suck) and then blend the 1/4 to rocker and 1/4 to rear cowl areas... then I get to do it all over on the other side! Ugh.
    13. #53
      Nicely done Blake. Way more work than I want to do on the Cougar! Lol
    14. #54
      Houston, TX
      Nice work Blake.
      Hope you don't mind but I'd like to copy your idea on the frame rail bracing. I'm working on a 65 Mustang fastback right now with DSE front suspension, and the owner/I were both thinking about ways to brace the front frame rails.
      Tu Ho
      Firebird V2-LS swap
    15. #55
      Oct 2014
      By all means! 90% of my ideas are stolen from or inspired by the work of others. That's what these forums are for! :-)
    16. #56
      Feb 2011
      Indpls, IN
      Awesome work. Thanks for the how to on the panel Gaps!
    17. #57
      Sep 2012
      London, Ontario
      Nice Work!
      73 Maverick Grabber Project
      My never ending project:
      https://www.pro-touring.com/threads/...hlight=grabber
    18. #58
      May 2013
      Texas
      The flexy heim joints are the only part that i'm iffy on (I like solid, no moving connection points which is up for debate but preference mostly)
      With that one item mentioned... Excellent build and eight thumbs up! Cant wait to see how this one progresses.
    19. #59
      Oct 2014
      You mean the braces on the top of the engine bay? I doubt they'll do a ton anyway, but yeah, heim joints can definitely move some. I can pre-load them as well though.
      And, thanks!
    20. #60
      Apr 2015
      Burlington KY
      looks good! Working on my 64 coupe, trying to get the drivetrain squared away so i can start doing the body work. Im used to doing body work and paint on the side but this car is freaking me out alittle. Good to see someone else being picky.
      "Racing is life. Everything else is just, waiting"
