    View Poll Results: What should I do?
    Voters
    17. You may not vote on this poll
    • LS3/T56
      15 88.24%
    • Procharged SBC/TKO 600
      2 11.76%
    Results 21 to 34 of 34
      Jul 2014
      Seattle
      LS Swap Vs. Procharged SBC
      Alright all, I know this has been done before... Many times... But I'm curious as to what you all think I should do in my particular situation.
      I've been pricing out an LS3/T56 swap and, as we all know, it ain't cheap! All said and done, I'm around $21-22k with a new 480 horse LS3 and T56 Magnum, and that's with a lot of shopping around (install labor included).
      The other option I've been considering is throwing an intercooled P1SC on my existing 383, at around 6psi, and putting a TKO 600 behind it. Power output would be roughly the same as the LS swap and the cost would be closer to $12-13k. Hence, the temptation to go this route, even though I love the idea of running an LS in my car.
      My Camaro is not a daily driver, by any means, nor will it ever be. However, for the few months a year I'll drive it (maybe 3-4k miles) I do want to be able to start it up, beat on it a bit at the track (auto-x and drag strip), as well as drive it wherever the hell I want without issues. I also want it to have that "Wow" factor when I pop the hood at shows, which I believe either would provide.
      Bottom line, if money were absolutely no issue, I'd go the LS route... However, that's not the case. While I live fairly comfortably, by no means am I rich. However, as a respected and well-to-do friend of mine once said to me, and it resonated, "you only live once and should do what makes you happy - you can always make more money." Still, I find myself going back and forth with this decision... First world problems, right?!
      Anyways... Help! What do you think I should do? I can't make up my mind; help me choose a path so I can move forward with one or the other.
      1967 Camaro "Yellowjacket"
      383 Stroker
      M21 4 Speed
      12-Bolt Posi w/3.31s
