    Results 21 to 40 of 51
    1. #21
      Aug 2013
      Shelton WA
      In the process of getting it running again I did some upgrades. I've switched the front over to QA1 coilovers and just need to do the rear. I swapped in a Holley Street Avenger and an Edelbrock EPS manifold along with a $20 swap meet Pertronix HEI and a 78 amp 12SI alternator. I also installed a Red Head quick ratio steering box with a new idler and pitman arm. The next major work to do is to pull the bench out and put in the Procar buckets and do the trans tunnel mods for the TKO600.
    2. #22
      Aug 2013
      Shelton WA
      As with any project changes can and do happen
      Body
      Fix the minor rust around the right rear quarter and wheelhousing.
      Remove the vinyl top and remove the trim studs and weld up any holes.
      Modify the hood with a Chevelle SS cowl scoop.
      Repaint in a similar color orange with silver SS style stripes.Going to a deep metallic blue with silver and red
      Interior
      Color change to black or dark grey Blood red
      Change out the bench for buckets. Something comfortable and supportive but not restrictive.
      Custom center console that may or may not go all the way to the back seat and back seat modified accordingly.
      Modernize the some of the features while keeping the classic look.
      Decent stereo system but not overkill
      Engine and drive train
      Mildly built 383 stroker with a GM serpentine accessory drive.Looking for about 400-450hp. Doing a 355 instead
      Upgrade to electronic ignition. Done
      TKO 5 speed with hydraulic clutch. Next to be done
      3.73 and an Eaton limited slip in the 12 bolt. 3.55 rear gears
      Chassis,suspension, wheels, tires and brakes
      Upgrade to tubular control arms front and rear. Done
      Larger front sway bar and adding a rear.Done
      Lowering springs all the way around. Went to QA1 coilovers at all 4 corners
      New shocks all the way around.
      Upgrade front brakes using factory type parts for ease of replacement.
      Swap rear drums for discs using factory type parts.
      Swap vacuum booster for a factory type hydraulic set up.
      245/40-17 BFG front and 275/40-17 rear Went to 255/45-18 on the rear
      17x8 and 17x9/9.5 Torque Thrust II wheels Went to 18x8 on the rear
    3. #23
      Aug 2013
      Shelton WA
      Finally installed the bucket seats. I oughta change the project name to Slow Ride with as slowly as it's progressing.
Size:  89.9 KBName:  91086861_10157516906594006_4026756226271412224_o.jpg
Size:  108.6 KBName:  90918966_10157516907174006_7554819698110496768_o.jpg
    4. #24
      Oct 2015
      Quote Originally Posted by SPLATT71MC View Post
      Body
      Interior
      So you are going a blue car with red interior?
      Car looks great so far.
    5. #25
      Aug 2013
      Shelton WA
      Quote Originally Posted by Alwhite00 View Post
      Eventually yes
    6. #26
      Mar 2013
      Country Flag: Belgium
      Always liked the monte carlo!
      Even though your are getting a red interior, i like the current bucket seats!
      And no worries in beeing slow, that is exactly the lane i am in :D
      (****lane but atleats we are making progress ;))
    7. #27
      Aug 2013
      Shelton WA
      Haven't made much progress in the past year. Between going back to school and in the last 6 months or so my health has been a problem. Well here's some progress on the engine for the car. The short block is a .030 350 that I originally built back in 1996 for a Blazer I used to have. While it was in the Blazer I swapped around cams and heads a couple times and when I sold the Blazer I pulled it with about 15k miles on it and stuck it on a stand in the corner of the basement. I pulled it out a while back pulled the factory iron heads and Comp 4x4 Extreme cam and cleaned up the short block. The short block has a factory steel crank and 4 valve relief flat top hypereutectic pistons(Sealed Power I think),a Comp Cams XR276HR hydraulic roller. I'll be topping it off in the next week or so with some Brodix IK180 aluminum heads and a Performer RPM Air Gap intake. From the research I've done and running the numbers through a Desktop Dyno program peak horsepower should be between 390-425ish and torque numbers should be in a similar range with a meaty torque curve. I know these aren't huge numbers by todays standards but for what I want out of the car they'll be fine until I can pony up the cash and build a LS based engine.
Size:  238.1 KBName:  193311919_10158595218674006_1930373823376900079_n.jpg
Size:  256.5 KBName:  195100616_10158595218389006_6870572270522737681_n.jpg
Size:  190.4 KBName:  195215959_10158595218489006_7624170847951206490_n.jpg
Size:  217.7 KBName:  194600896_10158609014034006_7079872783613911930_n.jpg
Size:  281.1 KBName:  195080784_10158609013829006_8284930764515229431_n.jpg
Size:  275.8 KBName:  194905925_10158609013659006_6013760539901056703_n.jpg
Size:  327.3 KBName:  194661271_10158609014474006_3270679058522234377_n.jpg
    8. #28
      Aug 2013
      Shelton WA
      Rebuilt the front brakes, I plan on upgrading to Wilwoods or Baers later on, I just want to reasonably stop. And finally installed the rear QA1 coil overs and not pictured a front UMI frame brace.
    9. #29
      Aug 2013
      Shelton WA
      Made a little progress, got the wheels powdercoated. I loved the polished aluminum look but hate polishing. More coming as the weather gets better, open carports suck.
    10. #30
      Aug 2013
      Shelton WA
      Made room for the TKO600, just have to do some clean up work and seal the seams and paint it.
Size:  364.1 KBName:  294196933_10159281970099006_7569520127947888394_n.jpg
Size:  355.9 KBName:  294430809_10159282081074006_1035338161868921842_n.jpg
    11. #31
      Nice work!
    12. #32
      Aug 2013
      Shelton WA
      Nice work!
      Most of it is a pre-bent piece I picked up from Speedway that I modified the rear section for a better transition to the rest of the tunnel. In the coming weeks I'm going to be installing the pedals and hydro clutch master and reservoir.
    13. #33
      Apr 2015
      Awesome progress and thanks for sharing! Keep chipping away at it.
      You’re motivating me to get off my ass!
    14. #34
      Aug 2013
      Shelton WA
      Quote Originally Posted by NorCal-SS View Post
      Not having a garage makes it tough to get work done in a timely manner. It limits me to pretty much to the summer months, late spring, early fall if I'm lucky. It doesn't help that I'm trying to keep it on the road as much as possible to be able to enjoy it as well.
    15. #35
      Aug 2013
      Shelton WA
      Participated in my first show a couple weeks back, Good Guys no less. Had a lot of fun doing it. Any progress working on it is on hold for a bit. At the end of June my father in law passed away and seeing we've been living in one of his rentals we need to find a new place to live seeing that all his properties are being liquidated. Thankfully we will have time to look and move. The plan is to be moved by winter and have a place with a large garage and/or a shop and then I can make some stuff happen faster.
Size:  536.9 KBName:  295252806_10159289615234006_5183184414091172884_n.jpg
Size:  454.4 KBName:  295268537_10159289622314006_6441627969432644886_n.jpg
Size:  426.6 KBName:  295429573_10159290495494006_1594698890490172866_n.jpg
Size:  310.0 KBName:  295432133_10159289774429006_5051674573865053366_n.jpg
Size:  157.6 KBName:  295443192_10159289774224006_6460802477945691992_n.jpg
    16. #36
      Aug 2013
      Shelton WA
      Well all major work is on temporary hold as my wife and I are in the market for a new house. I want the car drivable until after we get moved but in the mean time I'll still work on small bits and pieces to keep things progressing. I did recently get the back seat recovered to match the fronts and installed a new package tray cover.
    17. #37
      Nice work in the interior
    18. #38
      Jun 2017
      Utah
      Wow, what an inspiration. I love that you complete projects and get it back on the road. Great project-good luck in finding a shop (house too) and continuing.
    19. #39
      Aug 2013
      Shelton WA
      Quote Originally Posted by Threepointtwo View Post
      Well not all the projects on the car are complete. Some are just in a state that doesn't take it off the road It doesn't help that I added another project to the fleet 2 years ago that I'm trying to keep it driving as well. Once we get into a new house and I actually have a garage/shop I'll be able to progress more work in the wintertime. Trying to do major work evolutions and still enjoy spring/summer/fall shows and cruises makes it tough to do both. Once we're settled in I should be able to ramp up the progress.
    20. #40
      Aug 2012
      ft myers,fla
      Cool monte. I'm building a protouring/restromod 72'factory 454 monte
      86'monte carlo ss. Plan to build a bare bones protouring hotrod with a turbo ls1 and 4l80e.
