    Page 2 of 5 FirstFirst 1 2 3 4 5 LastLast
    Results 21 to 40 of 81
    Thread: Led Headlights
    1. #21
      Mar 2014
      Long Beach
      Quote Originally Posted by camrat68 View Post
      where did you buy your lights, Decline? I tried looking for "Ironworks" and had no luck with anything related to lighting.
      Jim
      Ebay from truck-trailor-direct for $331 plus tax.
    2. #22
      Aug 2009
      Central California
      Has anyone been able to find these in 5 3/4" for the early A Body cars?
    3. #23
      Apr 2010
      Pittsburgh, PA
      Quote Originally Posted by cspecken View Post
      JWSpeakers
      Model 8630s
      doesnt matter if its 64 abody or 72 its same dimension light
      72 buick skylark
    4. #24
      Aug 2014
      I guess i'm not getting it...I can't find any info on the 5/3/4 versions of the Round LED Headlamp, Complex Reflector Optics Design
    5. #25
      Celina, Texas
      Led Headlights
      Are the truck lites too deep to clear RS doors? (68)
    6. #26
      Nov 2011
      Riverton, Wyo,
      Just curious if anyone knows the answer to the last post? Can these be used with hideaway headlights. I would think with some mods to the headlight buckets.
    7. #27
      Apr 2012
      Woodstock, IL
      Led Headlights
      We've used them on two 69 RS front end cars. They do require mods to the buckets.
      -Dale
      SchwartzPerformance
    8. #28
      Jul 2013
      Gilbert, AZ
      Quote Originally Posted by Nothingface5384 View Post
      JWSpeakers
      Model 8630s
      I know it's an old post but just for future viewers... 71-72 Chevelle is not the same as the earlier Chevelles. 64-70 is the 5-3/4", 71-72 is the 7".
    9. #29
      Cornettsville, ky
      http://www.vleds.com/headlights/led.html
      or
      http://www.oraclelights.com/
      can use stock composite housings if you dont like the looks of the others.
    10. #30
      Jacksonville, FL
      I just swapped over to the truck lite 27270c on my 68 (from standard halogens). I got lucky and found somebody selling them on Ebay for $100 for the pair, the guy was trading in his jeep. Here is a comparison form the old halogen to the new ones. Haven't had a chance to see the difference (on the road) but the light pattern on the wall is much brighter and wider with the LEDs.
      Chris
      1968 Chevy Camaro SS
      LS3/4L70e, DSE suspension
    11. #31
      Mar 2012
      I'm Tempted to get 4 Hi/low versions of the Model 8630s
      I did that in my black 68 GMC C15, with relays that removed the head light switch from the power circuit. A thing of beauty at night.
      Had to cut most of the stock head light bucket out and hole saw the radiator support on the inner lights.
    12. #32
      Mar 2012
      Quote Originally Posted by nekkidhillbilly View Post
      or
      Oracle LEDs take a boat load of cutting to the head light buckets. Same with the JW Speakers or Truck-lite for most classic cars. Good news is that the aluminum housing is very stiff. I used them in a few projects.
      I've used the drop in LED bulb and unless you get the right housing, it really makes the light worse. I put an H4 replacement in my Ducati Monster 1200s to very good effect, but not so hot in the Ciba G-Code housings I used in my Jeep CJ7.
      I know it's a 4x4 site, but lights are lights. My friend Gil did a pretty decent comparison:
      http://www.jkowners.com/tech/lights/ In his review, he mentions HID drop in bulbs. I also lump LED drop in bulbs in the same bucket, as it's the quality of the housing, not the bulb.
      The Oracles were not out at the time, but I've run all the lights we're talking about. I'd place the Oracles slightly above the Truck Lites in performance and slightly below them in looks. Truck light also does not make a 5.75" light (that I know of). They do look more like old school headlights.
    13. #33
      Nov 2007
    14. #34
      El Paso, Texas
      I saw this just came out. Might be an easy solution if you already upgraded your headlights. I use Hella E-code headlights on my 65 Chevelle. I might pick up a set of these to try in 'em.
      https://www.superbrightleds.com/more...fan/2116/4805/
    15. #35
      Feb 2009
      N.J.
      Has anybody put the truck lites in a 70 -73 Camaro? If so, did you have to modify the headlight buckets?
    16. #36
      Feb 2009
      N.J.
      Just for everyones information, they fit perfect into a 1970 Camaro with no modification.
    17. #37
      Jul 2010
      Harrisburg, PA
      Check these out. Although these are listed as Mustang they will fit anything using a 7" or 5-3/4" headlight. Many styles.
      http://www.cjponyparts.com/headlight...-1969/p/HLA55/
      http://www.cjponyparts.com/delta-tec...r-1969/p/HLA2/
      http://www.cjponyparts.com/delta-tec...-1973/p/HLA4L/
      These can be used in any sealed bean style housing that accepts an H4 Bulb
      http://www.cjponyparts.com/oracle-li...3/p/BULBH4LED/
      Joshua O
    18. #38
      Central CA USA
    19. #39
      Aug 2009
      Central California
      Quote Originally Posted by David Pozzi View Post
      I am planning on running a set of 5 3/4 for my 1964 GTO from xtremeledsonline. They sell the same light you are referring to. https://www.xtremeledsonline.com/store/ Click on the LED Headlight Kits on the left side of the page.
    20. #40
      Mar 2010
      True projectors. Bought mine from dapper lighting.
