    Results 21 to 40 of 46
    Thread: CV Driveshaft
      Today I got a couple of beautiful driveline parts from The DriveShaft Shop. These will be going in a 1967 Cougar.
      Goodbye 100 years old u-joint technology and welcome to the 21st century...
      First is this 27 spline slip yoke for my T56 transmission:
      I do believe that a 32 spline version is also available that will work with TH400, etc...
      It is set up to use one of their 100mm CV joints.
      This beauty is a pinion flange for the 9" rear end. There are versions for the 12 bolt also available.
      It is machined to accept one of their 108 mm CV joints.
      Once I get everything installed I will measure for an aluminum driveshaft (with CV joints t both ends) to go in the middle. Concerns about driveline angles will be a thing of the past. The front and rear operating angles don't have to be equal and opposite anymore, as long as the operating angles don't exceed 9 degrees.
      Austin, Tx
      Those are nice, and they have that "cubic dollar" look to them. ;)
      As someone who has a little bit of driveline vibe in my car, this might be a nice option for me too at some point...
      Bryan (a.k.a. Carbuff)
      70 Camaro RS Hunk'o'Metal - Previous Project
      71 Firebird Project T.O.W. - New Project
      Quote Originally Posted by carbuff View Post
      The yokes are actually priced in line (even less than some) with other billet yokes on the market.
      Aug 2016
      Indiana
      Andrew,
      What has been your experience with thus drive shaft? I have a 70 chevelle with an ls motor 4l80e and the trans tail shaft sits 4* down. The pinion is at 0* so the drive shaft points up to the pinion. I have a vibration at high torque. I am running 850 hp so my question is will the cv joint hold up under this type of hp.
      Quote Originally Posted by Terryjr View Post
      Andrew,
      My car doesn't make enough power to really stress this type of driveshaft. However, my buddy TJ runs one in his Chevelle....
      TJ uses an aluminum shaft and so far no issues. The car is 3590 pounds, runs 9.60s @ 140 mph and pulls 1.4x 60 foot times...
      Dec 2010
      Fredericksburg, VA.
      Andrew,
      Is the double CV shaft a lot more expensive than the carbon fiber one you had pictured earlier? I was also wondering if you could tell a difference in drivability with the carbon fiber shaft. Specifically I'm wondering if the cf shaft twists to absorb shock loads. I have heard comments to the effect that a cf shaft just runs smoother and quieter in general than a steel or aluminum tube type.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Andrew,
      The double CV shaft will cost more, but how much depends on what you do. For instance, when I installed mine, I also installed a Mark Williams billet yoke in my 12 bolt. That yoke was stupid money and is actually more expensive than the CV pinion yoke. So really, if you are going to swap pinion yoke anyway, the cost difference is only the addition of the second CV joint. The plan for the Cougar is to swap the pinion yoke and use an aluminum shaft with CV joints at both ends.
      As for the carbon shaft, I don't really know that it made a lot of difference in quieting the driveline noise. I used to have a pretty noisy R&P whine, I had the R&P replaced, and the whine is less, but not completely gone. It's annoying. I hate all manner of unintended gear noise.
      Hope that helps.
      Apr 2010
      Pittsburgh, PA
      How would a c/f shaft work since the yokes are billet AL?
      72 buick skylark
      Quote Originally Posted by Nothingface5384 View Post
      You have to be more specific as to what yokes you are talking about. The transmission slip yoke and the pinion yoke are billet steel. To them bolts the CV joint that has a steel splined shaft that is bolted to an aluminum driveshaft yoke. The CF tube is bonded to that aluminum yoke. The sequence is repeated on the other side in reverse order.
      This is what it looks like on the transmission side:
      Dec 2010
      Fredericksburg, VA.
      Andrew,
      Those CV joint adapters, on the transmission adapter you said is for a 100mm joint and the 9" adapter is for a 108mm CV joint? Why use different sizes of CV joints?
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      Andrew,
      My guess is that it has to do with the spline count on the transmission. The T56 uses a rather small 27 spline output shaft. My Richmond 6 spd has the big GM 32 spline output and has the bigger CV. It's not unlike having different size u-joints for different application. Obviously a 9" rear can handle ample power, thus the bigger CV size.
      Nov 2011
      College Station, TX
      Watching this since I have factory CV's at both ends of the rear section of my Riviera's 2 piece shaft and they are a pain to get serviced and like you point out, very old technology.
      Central TEXAS Sleeper
      Experimental Physicist
      '64 Riviera T-type: 4.1L Buick Turbo6, 4L80E, L67 OBDII SEFI swap
      ROA# 9790
      Quote Originally Posted by CTX-SLPR View Post
      Does your Buick use the old style double-cardan CV joints?
      Nov 2011
      College Station, TX
      Yup... One just behind the carrier bearing on the slip section and another on the bolt on pinion flange. Going to have to replace/modify the rear section anyway for the planned swap to an 8.5/8.625in 10-bolt for more options.
      ROA# 9790
      I'd love to see pictures of that set-up!
      Nov 2011
      College Station, TX
      I'll see what I can find from when I've had it apart. With the X-frame the middle of the shaft is tucked up out of view.
      Right now the rear CV is not in good shape but I ran out of time before my most recent move to get it fixed.
      ROA# 9790
      No worries. I Googled around a bit and have a pretty good idea of what you have. It's interesting that the luxury brands of the time (Buick Riv, Caddy, etc...) all had two piece driveshafts with the double cardan CV joints. I am sure that was done for smoothness.
      Look at moder muscle cars. A 2011 Mustang has a 107 in wheel bases but uses a 2-piece driveshaft with dual CVs in the rear section. This is no accident. Modern IRS cars can get away with u-joints, but still use 2-piece driveshafts and rubber guibos to isolate driveline noise.
      I was looking at some build pictures of the Ken Block 1965 Mustang and this picture caught my eye. See anything familiar?
      Dec 2010
      Fredericksburg, VA.
      Update, I have been chasing a drive line vibration for the past three years. First I found a thrust washer missing in a cap of the original rear Spicer U-joint that was installed in my custom drive shaft. As I mentioned in a previous post in this thread, I installed a NAPA U-joint to replace the original to get the car back on the road and later ordered a pair of Spicers to keep as spares. Well I never suspected that the replacement U-joint might also be bad. In any case, today I removed the drive shaft to work on fabricating a DS loop and was stunned to discover that the rear joint I had installed last year was seized up. So I installed one of the spare Spicer joints I had and put everything back together. I still need to get it out on I95 for a sustained high speed run to make sure but it seems my remaining vibration is gone now. So for the past three years total I have been chasing a vibration which was first one U-joint improperly installed and then just my luck a second bad joint. Go figure.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      May 2010
      kitchener,Ontario,Canada
      Cough cough ...this is where a cv joint d.s comes into my mind lol
      Ryan Austin
      On Instagram ryanaustinss70
