    Page 1 of 5 1 2 3 4 5 LastLast
    Results 1 to 20 of 95
      Jun 2011
      SoCal
      TCI Engineering's 1971 Camaro
      Project #RedDawn
      Now that the C10 product development is nearly finished it is time to finally start the 2nd Gen Camaro development.
      This car will be used for product development and performance testing. It will be a fairly quick/simple build. We plan to design a light weight tubular front clip similar to what we offer now for the 1st gens. We will probably just do a head & cam package on the existing engine and throw a built 700R behind it. We will mini-tub it of course and try to squeeze as much tire in it as possible. Depending on how things work out this car may replace our '68 that we currently have in the line-up.
      Here is what it looks like now before we begin.
      -Jason
      www.totalcostinvolved.com
      Nov 2012
      Looks like a nice car to start with.
      _______________
      1969 Camaro
      1966 Skylark
      1964 Lemans
      1960 Biscayne
      Steve
      knoxville tn
      Wish the car we are doing was a 71 and was in this good of shape. Looking forward to the build.
      Jun 2011
      SoCal
      Nothing to crazy to report on this project yet but it is moving forward. Most of the front has been disassembled.
      Sal & Ed discussing some ideas
      -J
      Curious why you guys aren't planning to put a 6X auto in it??
      I've actually been drooling over that trans, but it's so cost prohibitive...
      1971 Camaro
      Jun 2011
      SoCal
      Quote Originally Posted by ULTM8Z View Post
      We would love to run one also but we can't afford it either. Or I should say the guy that writes the checks is a Ford guy so our Chevy budget isn't enough.
      -J
      Jun 2011
      SoCal
      The stock front clip is out and we've taken one of our 1st Gen clips and mocked it up
      After mocking up the fully welded 1st gen Clip it was now time to take an unfinished clip and mock it up (we left off all 6 mounting points)
      We left the slip joint unwelded so we could adjust the rear mounting point.
      The firewall mount was pretty close
      Ed checking the wheelbase and ride height
      More updates very soon.
      -J
      san diego
      knoxville tn
      Nice! I wish we were doing tubular on the 76.
      Dec 2010
      Will this car receive the torque arm, or shall we see an over-the-axle boulder holder?
      Jun 2011
      SoCal
      Yes, we plan on utilizing a Torque Arm system on the 2nd Gen.
      -J
      Jun 2011
      SoCal
      Ed is using some 1/8" plate to locate the clip for now. The upper tubes had to be moved to accomodate the inner panels. I will continue to post updates as we make progress throughout the design phase.
      -J
      Central CA USA
      Cool build!
      Thanks for starting it.
      Jun 2011
      SoCal
      The front clip is for the most part in the 1st stage of finalization. Fixtures are being made, first articles are being built so now they've moved onto the back of the car.
      We will be posting the weight of our clip very soon but we're fairly certain it will be at least 100 lbs lighter than stock.
      Torque Arm rear suspension mock up
      Coil-Over crossmember
      -J
      Mar 2012
      Looks awesome. What spindle are you using in front? Mustang II, Corvette?
      I like the Ride Tech Coil overs, would also like to use their A-arms in my 73 Camaro build. Love the idea of a clean sub-frame with a rack and pinion.
      Jun 2011
      SoCal
      We use our Custom spindle on this application.
      The control arms will be proprietary with our front clip so the ridetech arms won't work.
      -J
      Jun 2011
      SoCal
      Now that we've completed full mock up of a stock tub suspension kit it was time to move onto a kit to work with a mini-tub.
      Our speaker tray was also in bad shape so we will make a new one.
      -J
      Jun 2011
      SoCal
      It's been a few months since Ed has allowed me to post pics so bare with me as I catch you up to date.
      The front clip is very close to completion.
      -J
      Looks awesome!!
      1971 Camaro
      Jul 2013
      Gilbert, AZ
      Looking great, can't wait to see it done!
      And I don't know what the exterior plans are, but I beg of you, please keep the full width front bumper on, or do a full Rally Sport conversion, nothing in between.... pleeaasseee!
