Results 1 to 19 of 19
Thread: Serpentine setup
02-26-2009 #1
- Jun 2005
- 543
Serpentine setup
Prices of serpentine setups for a SBC have jumped in the last 5 years from $50 used to $150 used.
I'm wondering if anyone here has made their own brackets and done it themselves cheaper?
My Silverado parked out front has a 4.3L v6, which is essentially a SBC with 2 cylinders lopped off from what I understand.
I'm seriously considering pickup up an extra tensioner and making up my own brackets using my Silverado as a model.
Thoughts?
Mathius
02-26-2009 #2
I've been thinking alot about making my own serpentine setup for a pontiac engine. The march ones are nice but expensive and a little too blingy for me. I don't think it would be too hard to make brackets if I find a ac compressor, alternator, ps pump, etc that I would want to use. I'll have to do some junk yard trollin. But I'm interested to hear if anyone one else has done it
Traven
02-27-2009 #3
- Jul 2006
- Chesapeake, VA
- 678
The 4.3L setup bolts right onto a SBC, if you want to use it for a model you shouldn't go too far wrong.
Cars are meant to be driven.
John B
02-27-2009 #4
- Dec 2006
- Los Angeles
- 334
02-28-2009 #5Well I'll sure try, I have an F body LS1 laying around. I might take the accessories off and see if I can make them work with some custom brakets, and if I do then I can buy a second used accessory setup. But I'll check some junk yards and whatnot to see if I think parts off a different model will work better.
Traven
02-28-2009 #6My friend's Silverado (89-93ish) Has a stamped steel serpentine setup. Fabbing you own isn't oput of the question.
02-28-2009 #7
- Jun 2005
- 543
Might not get to this one until the summer. The Chevelle is being stored away from my house until then.
But I'm open to ideas or suggestions until then. I'm not sure what the best way to do it will be. IIRC serpentine water pumps spin the other way? So a water pump swap would be necessary... might go ahead and get an aluminum radiator while I'm at it, and build a new radiator support. Get the whole job done at once.
I would think it would make sense to just take measurements off my silverado while the components are in the vehicle, that way I can use the same belt, OR should I just try to make up a jig, and copy the factory parts as closely as possible instead of making up the components to my own design using the measurements off my current setup?
I also have an a/c compressor on the silverado, no a/c on the chevelle. Can I put a compressor in, and not wire it or will that destroy the bearings?
Mathius
02-28-2009 #8Troy at rad ride has done it before so it can be done. When i watched him he just used cardboard and cut out for his accesories and brackets and then cut it out of aluminum.
Jeff
02-28-2009 #9You can install the A/C compressor and not use it. If you never turn on your A/C in a car with it installed it is the same thing.
On the other hand, everything has a limited life. Never engaging the clutch means that the bearings for the pulley will always be used. That mean that the bearings will fail a little bit sooner. The question is when, and I don't think it'll be "sooner" enough to worry about.Jason Scheer
02-28-2009 #10As for making your own brackets, yes, it is possible. The advantage to the OEM setup is that it is sturdy and light weight. If you forgo some of the ribs and reinforcements you might find the belt coming loose due to flex.
Not to say that you can't make something that works, and works well, but it may take more trial and error than you think.
Don't think I'm trying to discourage you. I just wanted to say that this may not be as simple a project as it seems at first glance. Maybe you'll come up with a system that people are willing to buy and you could become a new vendor here and make millions.Jason Scheer
02-28-2009 #11
- Jul 2006
- El Paso, Texas
- 411
I've always found it ridiculous that an aftermarket system can run over $1000 dollars for something that you could get from a junkyard that does the same for a tenth of the cost. I've used the 90-up Camaro and Caprice setups and polished,chromed, or powdercoated they look awesome. Plus parts are off the shelf and easily available. For me the biggest thing is the tensioner. Sucks having to adjust the brackets or bars on the aftermarket stuff every so often. Take into account the time needed to fabricate your own and maybe $150 aint so bad. I've spent tons of hours and materials sometimes trying to roll my own and it doesn't always come out as good as the original. That being said, ain't nothing like being able to say "I made this". <g> My .02
02-28-2009 #121LE Camaros didn't have a/c. They used an idler pulley that mounted in the location of the compressor. GMPP has 2 versions of the kit. The non a/c version has that idler which is available seperately.
http://store.summitracing.com/partde...5&autoview=skuThe needs of the many outweigh the needs of the few.
02-28-2009 #13
- Jun 2005
- 543
Depends on what kind of a design is necessary. I have some 3/16" plate material in storage that will probably work fine if I gusset it properly. If that works, I'm only out $30 for the tensioner + whatever it costs me to deal with the a/c issue. Might be able to find a junk compressor on Ebay for cheap and just use that until I get a real a/c unit.
$80 is pretty pricey for a temporary solution. Sortof defeates the purpose of building my own system, when I can get a full setup used for $150. Maybe I can find a used one, or see if the non/ac version of the silverado just used a shorter belt.
Mathius
03-01-2009 #14
