Results 1 to 10 of 10
Thread: G-Body Solid Body Bushings
07-30-2018 #1
- Nov 2006
- Austin, TX
- 41
All,
I'm in dire need of new body bushings for my '87 Monte. the car is just in the very early stages of work and is pretty rough, however my original body bushings
are shot.
-Has anyone experience real-world drawbacks to using the aluminum solid bushings?
There is often commentary (on other sites etc.) about worries of squeaks, galvanic corrosion, etc. However, solid bushings are used frequently on the subframe cars such as 1st/2nd gen f-bodies etc. also many of the modern cars have a mix of aluminum and steel components in the engine and suspension areas.
-harshness issues? modern cars done have body bushings and solids are oft used in the A/F cars.
-corrosion concern? I don't live in the rust belt and i won't drive in rain much.
-noise issues?
I am thinking of the TRZ pieces for G-Bodies
https://www.poormanmotorsports.com/p...ount-bushings1
however these come bare 6061 and recommend not powder coating due to tolerances.
if I get overly concerned with possible noise i can use these isolators from SC&C
http://scandc.com/new/node/982
or just cut my own from material i gather elsewhere.
I contacted SpeedTech to see if they made any for GBodies, since they have real nice ones for F/X cars
http://www.speedtechperformance.com/...rod/prd118.htm
already anodized. but they don't make any for G's.
I found a place locally that annodizes aluminum so i could have that done but i haven't inquired as to price. I'm afraid to ask...
http://bic-texas.com/hard-coat-anodizing/
6061 should anodize nicely.
I'd rather have delrin versions but I don't have a lathe nor ever used one so the results, if i had access, would be pretty sketchy.
car, for relevance:
near term plans:
18x9 w/ 275s (done)
5660 front springs
tall upper/lower b-joints
upper A-arms
rear 150lb/in springs (2" drop)
exhaust rework
Body bushings
farther out:
serpentine setup (in a box)
T56 (under the work bench)
C6 Z51 brakes
box the frame w/ supports
someday:
3-link rear
watts link (8.8 or 10bolt? dont' know how yet)
oh, and i didn't post this in the body section as this really isn't 'body work' and is more along the lines of chassis mods...Morgan
'87 Monte SS
07-30-2018 #2
- May 2015
- Island Lake, IL
- 816
